Recommendations for a scanner - Check engine light on
Check engine light on after I filled with gas last night. It happened on my 2006 C6 Z06 for the first time. I've had it happen on my C5 and I could reset the code manually, but not on the C6.
I tried the normal stuff, starting the car a few times, and made sure the gas cap was on correctly. Now I guess I'm headed to Autozone so they can check the code and clear it. I'd like to buy a scanning tool so if this happens again, I can do it myself. What do you recommend? And also any recommendations on how to stop this from happening? Should I replace the gas cap? Thanks!
The code you had nothing to do with the gas cap, it would have said evap system if it was. So you wasted some money. You cannot throw on parts when you get a code hoping it will fix it. In addition sometimes codes happen as a glitch, you clear it, if never comes back you had a glitch, if it does you have a legitimate problem that needs to be properly diagnosed. And for that you need the shop manual. If not do inclined, and you have to take it to some place for it to be diagnosed, this way at least you know the effected area so the dealers cannot bs you and try charge you for something else, which is known to happen. That happened to me and they were red faced when i knew that they were bs ing. It increases your knowledge and the awareness.
Also, if you are an On Star subscriber, they can run the codes for you.
Fast Cars & Horses (09-18-2016)
Most of us can't screw the cap in the wrong way (turn clockwise until the threads engage, then pull on the cap to finish closing and make sure that three clicks are done before stopping) without getting a CEL the next ignition cycle.
Cherokee Nation (09-19-2016)
Another bad practice is to just throw new parts, at random, in the general direction of the code.
And it is unfortunate with any modern car that there is such a gigantic leap in diagnostic tool cost to read the other three code sets - B, C, U codes.
Or, say, hold down the recirc button and the trunk release and the nav/radio screen becomes a Tech 2.
And to exacerbate that, every manufacturer has created its own proprietary system to do the exact same thing. None are available/affordable to the public. Enthusiasts seek to acquire these tools, but even so, they get outdated.
Case in point, I've owned Jaguars on the Ford platform. I've spent a fortune on Ford's WDS, then the newer IDS, even that is now updated and Jaguar has left Ford.
Same thing with GM, I've headed down the Tech2 path but already outdated. I used to be into Mopar too, but thankfully for my wallet, not in recent years.
Someday, prob 20 years from now, these relics are going to become unrepairable.
