Traction Control Issue
I tried searching for this first... when I press the traction control button, the dash light turns on and the DIC says "Traction Control - Off". When I press it again, the light turns off and the DIC says "Traction Control - On". 2 quick presses only cycles thru Off and On. I don't see "Competitve Driving Mode". Holding the button down doesn't appear to do anything.
Hence with trouble codes, it will lock you out of comp and all off modes.
Speed07 (09-24-2016)
Hold the button down for about 5 seconds.
Thanks for the info. I noticed my left rear tire reads 0 PSI on the DIC. The tires are non run flats at 30PSI. Could a bad tpms sensor cause my issue?
