06 Pass side window -
So my window motor took a dump. So i removed the window and all that jazz. But the lil mounts that go on the window came off. Not sure if they stick on to the inside of the window or the outside of the window.. And what is the best option to ahear them to the window.?
http://imgur.com/a/djeAZ
I just did my 07 pass side glass... the rubber needs to stay on the clamps,not on the glass.
The rubber SHOULD be glued to the clamp surface grabbing the glass on both sides.
This allows adjustment fwd & back so you can line up the glass to the depressions from the old glass position in the weather strip (s). Make sure you index your window glass when the job is complete.Otherwise the glass will not do the drop down when you open the door.
Mike
Mike
Mike
Mike
