ARP Wheel Studs and Open End Lug Nuts
I am about to do some upgrades to my C6 Drivetrain. While I am at it I am installing ARP Wheel Studs. Since they are 2.5" long I will need Open End lug nuts. I am using the OEM Base C6 Wheels. I am very picky so function, fit and finish are very important to me. Does anyone make Black Open Ended lug nuts that won't stick out a mile and look like a Ricer? Please post up Mfg. Part# and Pictures if possible.
Received 2,060 Likes
Hey 7 went true this already factory studs in my car at list are the bull nose type and they are the best sense you cant cross a thread and as far as I know the ARP are not I used Moroso but there is a caveat they like to rust so I use a dry spray lubricant.
https://www.summitracing.com/parts/mor-46245/overview/
And for open end lug nuts strong and light weight is my priority these are steel mines came in at 26 grams they also come in all colors.
http://www.ebay.com/itm/Muteki-31886B-Deep-Black-Open-End-Set-of-20-Lug-Nuts-Adapter-Key-12x1-50-/131434393693?_trksid=p2141725.m3641.l6368
I found the best way to install them is to draw them in with a breaker bar and lots of oil sense speed sensors don't like the hammer too much and while in the process try not to drop the spindle which contains the speed sensor.
Muteki 31886B Deep Black Open End Set of 20 Lug Nuts Adapter Key 12x1 50 eBay
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
Used to be a vendor back in '11, SP Engineering, had TiTek lugs.
http://www.sp-power.com/ne/index.php...nds/titek.html
Not sure what OP is but I have been doing alot of searching. Studs are 2.5" from shoulder to end of threads. With my calculations that leaves approximately 1.75" past the face of the wheel. I don't want the lugs to look funny sticking way out. Most of the open end lugs nuts are 1" or 2" long. I may just have to cut down the studs in my lathe and use the stock lug nuts. Yes I am very picky about fit and finish. I hope this answers your question.
A point to remember, no matter which way you go, is that any lugnut you use should have at least 12mm of thread. If they are closed end lugnuts, there should be enough space for the leader after you have rotated the lugnut at least 8 full turns of thread engagement and the turns are greater than those needed when mounting the wheel.
I have them as well.
Just remember to use antiseize and reduce the tightening torque!!
KD
Received 8,919 Likes
If you can get by with stock length studs with the thread all the way to the end buy some Dorman stock replacement studs at your local auto store. Then get Extended Thread Lug nuts that thread into the stud opening in the wheel. With the extra 1/4 inch of threads on a stock length stud and the extra quarter inch of threads on the extended thread lug nuts you get plenty of thread capture with these nuts. I got these lug nuts from CCW because I had to run a spacer with their wheels when using the CCM rotors.
When you see them mounted on the studs they look like the GM standard stainless steel capped nuts but they are solid and chrome plated. They look like a Gorilla Nut but I couldn't find any Gorilla lug nuts that weren't locking nuts which makes them become a huge PIA when swapping wheels at the track. If you are interested in them call CCW. They work fine with the stock wheels and CCW wheels. They do hold up much better than the stock lug nuts because they don't have a cap that will distort and fall off. They can take a beating from an impact wrench many times and keep on working and looking good.
Bill
Bill
HOXXOH (10-19-2016)
