High Performance Rocker Arms
Pretty disappointed to see stamp steel crap rocker arms on my LS3 and looking to upgrade with something under $500 if possible. Just want to go a step up from what I have and there's way too many to choose from. Motor maxes out at 7200, 780-820hp. BTR dual valve springs, titanium retainers and HD pushrods already installed.
Any recommendations?
Unless you are willing to spend a lot don't bother. Aftermarket LS rocker arms usually arent very good unless they are Jesel or in that price range. The stock ones will be fine at that power level, and you don't have clear valve covers so just do the trunion and call it good in my opinion.
Looked into the OEM rockers and they're actually pretty strong so gonna keep them and just go with the trunnion upgrade, agreed Jessel would be a waste of money
Bone stock. Trunnion downgrades are just a waste of money to make them less reliable.
Naturally I'm looking for justification for the $130 I just spent buying the Comp Cam trunnion upgrade.
I'm far from the kind to waste money, just never cut costs on engine internals or anything that has a chance for wiping out the motor
Looked at those a while ago, super nice but I'm way over budget on my $10k build already and no where near your HP level. Didn't hear any definite no-go on the stock rockers (other than trunnions) so I should be pretty safe
[QUOTE=NJ_phil;1593271579]Looked at those a while ago, super nice but I'm way over budget on my $10k build already and no where near your HP level. Didn't hear any definite no-go on the stock rockers (other than trunnions) so I should be pretty safe[/QUOTE
Stock rockers work well and many high hp builds use them. Shouldn't be an issue.
Just be advised that they'll be 1.8 ratio.
http://raceconsultingagency.com/i-22...ELUxoCgwPw_wcB
http://www.jegs.com/i/COMP-Cams/249/1678-16/10002/-1
https://www.summitracing.com/parts/cca-1678-16
http://www.compcams.com/Instructions/Files/151.pdf
KW
For what it's worth, I went with the BTR kit because the clips looked a little stronger and it was a few bucks cheaper anyway.
Don't understand why you say that. Read and heard about a few that had the bearings walk out the press fit and figured a set held in with C clips would solve that.
Thanks for the replies guys... I cancelled the trunnion upgrades because they are 30% the price of a full blown roller set and might not even be an upgrade, depending on who you talk to. Seen more than a few rocker failures on older big blocks which made me think when I pulled off the valve covers.
Will the stock ones work?, sure... will new trunnions be better?, probably. Although I don't have the money to **** away on needless BS, I do believe on doing whatever and spending whatever is needed on motor internals to have peace of mind. I don't want to be looking at the tach and wondering what's going to let loose, or pulling valve covers off after a day at the track to see what's going on.
I love the aluminum roller rockers and spent big money on them years ago and surprised to see them under $500, so I'll be getting them as soon as I calm down the wife after she saw the latest credit card statements. The cam I just put in is pretty low lift (.598") and the motor might benefit with some 1.8s. Just putting the spring kits in now and will check PV to see how close things are. Rough calculations show .633" with the 1.8s and the last thing I want to do is run a tight PV.
Because he knows.
Comp sucks and failure has skyrocketed on trunions.
Stocks hold up very well for modded motors.
The newer brass bushing inserts have good possibilities but not enough track record to call an affordable upgrade as of yet.
.................The cam I just put in is pretty low lift (.598") and the motor might benefit with some 1.8s. Just putting the spring kits in now and will check PV to see how close things are. Rough calculations show .633" with the 1.8s and the last thing I want to do is run a tight PV.
The valve opening and closing events are more critical (in regards to PV clearance) than the lift.
FWIW.....my cam in my daily driven LS3 is 229*/242* duration with 114 LSA and .668" lift......and I'm not even close to having issues with PV clearance.
Jus' sayin'.....
KW
What is the duration and LSA of the cam?
Jus' sayin'.....
KW
Jus' sayin'.....
KW
Yes he does... Not that I was questioning him, just that needle bearings were getting bashed and I took a look at those Ultra Golds and assumed they also had needle bearings so was wondering how they could suck if he had them.
Turns out they have something else... need to look into it
