NPP exhaust issue
NPP exhaust issue
Several years ago, I purchased a factory set of NPP exhaust. I then purchased the retro-fit kit and the Lear to U kit from the now out of business Sunset Orange Creations.
Everything was perfect until someone backed into my Vette at a local grocery store.
A reputable body shop made the repair and all seemed to be well.
Unfortunately I took ill and the car was not driven by me for several months.
Very rarely did I run the Vette in quiet mode, but I had enough drone one day, and tried to put the exhaust in quiet mode....nothing.
As I backed into the garage the quiet mode went into effect as soon as I shifted in reverse and to make things stranger....with my foot on the brake (still in reverse) I pushed the homelink button and the exhaust went into loud mode.
I am not an electrician nor do I possess mechanical skills.
If there is anyone out in the forum that has any suggestions, I would greatly appreciate the help. I am not to keen on having the body shop trying to fix this problem.
Thanks in advance for any help you may offer.
good news is it sounds like a plug got mated incorrectly or maybe a missing ground connection. I suspect you'll have to take it to a reputable shop and let them pop the tail lights out and check the wiring located behind the rear fascia. Out of curiosity, are the back-up/tail/brake lights functioning correctly?
NPP exhaust issue
NPP exhaust issue
Who installed the retrofit kit? Did they install it near the rear bumper? Are you able to re-create the valves opening/closing by putting your car in reverse?
I added NPP to my 2006 with a switch on the console, and I put the controlling solenoid in the passenger foot well. There is nothing in the rear to be damaged with my system.
NPP exhaust issue
I don't feel qualified to to do this search and rescue mission but value this forums imput and reccomendations, which I can then pass on to the mechanic. Thank you again for your imput and the suggestion to rewire per your installation.
The retrofit kit was installed by a shop in Naples, Florida. This is probably the shop I will return to. As per the instructions the solenoid is reachable by removing the right inner taillight and my guess is the body shop did not pay attention to this wiring when removing the bumper and rewired incorrectly.... Probably to the back up lights. Somewhere there must be a plug or a pair of wires laying loose inside the bumper.
