ARH 2" Header install
I posted this in the Z06 section as well but thought it might get more responses here.
I'm getting everything put together to install my ARH 2" headers. I just wanted some verification on a couple of things.
1. I'm going to get an ARP stud kit. Looks like part # 434-1301. Is
that right?
2. I've read in other posts to use GM exhaust gaskets instead of the
gaskets that come with the headers. The part # I'm finding for
them is 12594171. When I look for these online it shows them
having "D" shaped ports when the ARH 2" are round. Is there
different part #?
Thanks!
Ryan
that right?
different part #?
Thanks!
Ryan
Former Vendor
I would be careful with buying header studs as some might come into contact with the primary tubes of the headers and could make the install very difficult. I would go with arp header bolts instead.
You have the correct part number for the manifold gaskets. I rarely use the gaskets that come with header kits. More often than not, the stock gasket will be fair superior.
I run the OEM gaskets and ARP header bolts.
RyanT (10-19-2016)
Hinson sells them. Look at their website.
My headers have a 3/8" flange. Bolts fit perfect.
RyanT (10-19-2016)
