Swapped to aluminum racing seats....
Just finished installing a pair of Kirkey intermediate racing seats 60 lbs saved compared to the original 3lt car seats @ 50 lbs each.
Used sliders on both happy with the results.
NYC6 (08-28-2019)
Yes factory seat belts with impact tensioners as well looking into incorporating original seats side air bags to new seats at later date.
Will post pics later after giving the car a much needed shower after working on and off on it for about 3 weeks sense the air bags were disconnected and seats removed battery off, is wash time.
Sliders off eBay
http://www.ebay.com/itm/Universal-Du...-/121876458295
Their hardware is junk I used SS flange nuts and bolts 8mm x 1.25 thread 16mm long to bolt sliders to seats made my own SS brackets to connect sliders to floor.
Not kitting these seats fit like they were made to the car however truth is they really don't fit as they come but need some massage and labor of love that's all.
Incredibly comfortable I had my upholstery guy add the head rest area an inch of padding to lean back like 3/8 and be on the head rest just like oem seats.
I also remove some of the entry side support to make it easy to get in and out.
Sliders off eBay
Do you have air bag lights on the dash?
I want to do something very similar.
thanks.
thanks.
Xboostx, I am interested in the weight reduction but mostly interested in getting my seats lower and further back.
I assume putting manual sliders on would make that entirely possible?
Quick note, these seats as the ones I'm using are deceptively more comfy their looks suggest, our road race car had Ricardo racing with side bolsters and they were nothing but torture after switching to the intermediates the car became a joy to drive sense that particular car is white we order a set of red covers and they are sweeeet.
Do you feel like that rear seat bolt anchor is legit? looks fabbed up legit spacing wise, but is that quality metal and re-enforced at all? and an extra hole drilled in it? haha, not trying to be a hater, just curious if you are keeping that as is? I used to get a lot of **** for making my own seat brackets in my old drag car real similar to this, so i noticed it immediately.
These are 1/8 x 1 1/4 inch wide stainless steel brackets
welded and bolted to the sliders after been bended twice they become really tough and way stronger than the 16 gauge stamped mild steel factory pieces and are bolted to the original mounting points.
