Does anyone make a good diff brace for an Auto C6?
BIGMAC
That's the same setup I have (A6/Z06 diff) so now I'm really getting worried. What would cause the ears to snap off the difference like that anyhow? I've launched my car dozens of times with the same NT05Rs (and M&Hs) on the street, and with the Nittos it's spins so violently through first that it's on the limiter the minute my foot hits the floor. I guess the only thing that saved me so far is that we don't currently have a track.
If ECS does a batch of those braces, I'm in for one too. I want to order a fuel system from them anyhow...
Mine broke on the first pass at the track on the 15's. It dead hooked and ripped out of the hole for a split second and boom. It snapped as it was getting close to shifting to second.
Holy ****, that diff housing is FUBAR. Did the trans grenade as well??
It would be really nice to know the actual cause of this.
Something out of the ordinary has to happen for these breakages. I have the stock C6 diff case (built internal), which is not as strong as the Z06 case and never anything like this. I have at various times broken an axle, an output shaft, twisted the intermediate shaft, and broken the spider gears. Never had any break or crack of the casings. Hundreds of launches on it over the past 5 or 6 years.
BIGMAC
With mine, something got put in a bind. I'm not sure if the output shaft snapped first and bound up breaking the rest or the other way around. Regardless... it sucks and it's an expensive repair. Lol
Yeah I searched high and low for an upgraded output shaft but OEM was the only option. Cryo-treating may help but I'm keeping my fingers crossed that I don't have this issue again.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
We are working on this guys, I am putting together a trans and diff now to mock up what we have. I'll PM you when completed.
#34
#36
Can you give us an idea of if and when you may be able to provide the A6 brace? Hopefully my car will be going back together soon.
BIGMAC
#38
However, the serial number on the transmission indicated it had been built some two years prior to when my build was started so I can only assume my builder used a transmission that had been in another car and not the "fresh build" I thought I was getting. Another sign something was not right was the converter that was in the trans was PATC not the Pro-Torque I ordered. While I am disappointed that my car builder apparently did not install what I was expecting, at least this provides a possible explanation why the trans output shaft broke on my third run. Who knows how much abuse was on the transmission that could have contributed to the shaft failure. I sure hope so since this has been a very costly fix and I can't afford another one!
BIGMAC
