fact checks on tuning
So I learned of this guy that tunes/ modifies, cars as a side business at his home. Charges $350 for a tune. I have a stock car 6spd-05- I didn't think it would be worth but figured id call him anyway. He claims there is a bunch of stuff in our ECU that can be removed for a bit more power. Mainly, codes that restrict torque even when traction control is disengaged. He also said if I came back later down the road w some bolt-on's he would only charge 100 for a re tune
He wouldn't use a dyno on my car, simply delete some codes then take the car for test drives to tune a little further
Then I find companies like texas speed that sell mail order tunes for a little less- I would assume they are doing the same thing as this guy would?
Which is the best way to go in this scenario? Will I even notice a difference on a stock car?- I hear some people say yes, others no.
Is this something I can do on my own with a laptop and some research?
I know this is a highly talked about subject- I have done some searching- just hoping someone can set the confusion straight- thanks
IMO get HP tuners and do it yourself. Super simple if you can read.
Yes, he is correct. C6 vettes and most GMs have torque management that limits torque. Just disabling that makes a big difference in delivered power. You can also disable the 1-4 shift, speed limiters, adjust fan settings, etc etc etc. Even a bone stock car should have a very noticeable difference with a tune.
That being said it all comes down to the tuner. This guy could be great or a flaming idiot that doesn't know what the hell he is doing. That is why I suggest anyone with 1/2 a brain just get the software themselves and do a little reading, and then you can do all the same adjustments.
If you are convinced on getting a tune and not doing it yourself I would go with a reputable tuner such as Texas Speed , Chuck CoW or Diablo Lew . They all need you to buy their interface to log and load the new tune . I went with Diablo Lew and a Diablo I1000 for my Header and TCM tune and I am very happy with it .
Now for the next steps ... I will have to use HP TUNERS or have the car professional tuned when I purchase my cam
Dave
Dave
Chuck CoW (01-23-2017)
At wide open throttle, the system is in open loop (not using the 02 sensors), and it's all tune that will either make the engine run correctly, or blow the motor instead.
So without a dyno and sensors to get the tune right during your WOT pulls to begin with, then all you can really do is keep it running rich/ ignition timing pulled, and work with data logs to tweak these long term instead.
Truth is, within about three dyno pulls, should be able to get the open loop tune spot on so the motor is going to put out as much HP that is avablile, then just a mater of some street time to make sure the rest of the tune is correct as well (transitions from open to closed loop, and back).
Hence with a dyno, your able to see what the car is making throughout the rpm range for both power and torque, to tune in the entire power range instead.
Dyno is nothing but a tool to let you make pulls without getting a ticket. Nothing special or magic. If you can do a pull on the street, that is better than a dyno IMO.
For what he wants, he doesn't even have to touch WOT fueling/etc.
Received 2,061 Likes
I'd suggest getting HP tuners, downloading your stock tune, and doing baseline scans at the track. Then getting a dyno tune by a local professional and note the differences between the old and new scans. After that, you can make small tweaks to the dyno tune whenever you choose and after any mods, without the fear of doing something really bad while you learn.
Not only will the timeslip reveal the car's performance, but also your performance of how well you drive. It's a record that your butt dyno can't replicate and you get to have some fun in the process.
When I did my tune I found the most well respected guy around and researched his work for 5 years back before pulling the trigger.
Car is a monster now and it makes all the difference.
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Doing it yourself is CRAZY. You won't get the most out of it and you also risk destroying it....
Also, there is no way to get the CoW BOOSTER! doing it yourself.
Chuck CoW
Its the best mod on my car next to chuck's trans tune.
OP there are other ways to achieve the same results
Dave
