rear sway bar help
rear sway bar help
I currently have the johnny oconnel sway bars and I need a rear option that doesn't protrude lower than the subframe. I road race the car and handling is of utmost importance, so some toothpick bar isn't gonna work. I am making custom exhaust so clearance is not a concern...it just can't stick below the subframe/crossmember.
Thanks!
Thanks!
Sounds like to me it's an endlink adjustment issue. If you shorten your endlink up it will allow for the bar to roll thus not hanging lower than the rear cradle. I would try adjusting before you go and purchase another brands bar.
http://1speedway.com/index.php?route...tegory&path=76
I have an APR diffuser and it works fine with that one.
Sorry, no clue what to recommend. I keep my car at my car condo and it is winter here, so I can't measure anything.
