Which oil cooler to go?
Hey guys
Recently swapped LS376/480 to my 05' I have fast 102, milled heads, and a tune. Yesterday air was about 50 degrees. And my oil temp was 221 while i was in the traffic and was about 208-210 while cruising in the highway. I think which means I need an oil cooler for upcoming summer days. I know oil temps above 250 can mean trouble so I dont want to risk anything. Max I saw with my Z was about 245 on track days
My question here is which cooler to go. Is Z06 cooler too big? Is Z51 cooler too small? Are there any aftermarket coolers can do the job? Ive done some research. I read some people said Z06 cooler is kinda too big for a LS3. And does the Z51 cooler worth all to effort to put it in? I need some suggestions
Since the car is my daily im not taking it to track or anywhere. And in the hottest time of the year its about 95 degrees here. And changes between 50-70 over the most of the year.
Thanks,
Thanks,
Those oil temps are in the normal range, especially with a stock thermostat. If the car is street driven, an oil cooler isn't really needed. If you insist on running one, a good option is to run the Z51 style radiator, which has an integrated oil cooler. You can either use an OEM GM rad or an aftermarket like a DeWitts. Then just use the OEM Z51 oil cooler hoses to plumb it. The stand alone air cooled oil coolers (Gran Sport/Z06 styles) aren't a great option for a daily that sees air temps in the 50s...takes the oil too long to warm up.
Supporting Vendor
Hey guys
Thanks,
Thanks,
But if you want to be on the safe side, the Z51 cooler is probably a decent option. The Z06 cooler will have a harder time getting up to temp due to the lack of an oil thermostat.
One option is to go with the Z06 cooler and our upgraded oil line kit and thermostat. This way you will have more cooling capacity in case you do an autox or track day, and your oil will get up to temp faster than both the factory Z51 and Z06 cooler setups.
Here is our line kit upgrade: http://www.improvedracing.com/oil-co...ade-p-767.html
And here is the Z06 cooler: http://www.improvedracing.com/coolin...358-p-332.html
You could also go all out and get our complete performance kit for another $100, and your oil temps will still warm up just as quickly: http://www.improvedracing.com/oil-co...kit-p-768.html
I think the best bang for the buck would be to find a used Z06 or Z51 cooler for cheap, and get our upgraded thermostat and oil line kit. That's probably what I would do in your situation.
__________________
Call Us: 407-705-3054 MON-FRI 10am-6pm EST
Like Us: Facebook - Twitter - Youtube
Instagram: @ImprovedRacing
Tag Us: #improvedracing
<My 2006 Z51 came with a cooler in the radiator for the oil, but when I upgraded to a Z07 (ZR1 with normal ends) all aluminum radiator, I also installer an early Z06 oil cooler. Now my temps are so low on the street that I built a carbon fiber filler to get oil temps up. Low oil temp is bad for your engine because the additives don't really work well until you get to around 180+ degrees.
ogulcanio (02-27-2017)
Honestly, if you're not tracking the car at all, you will probably be okay. It may get a little warm in traffic in the Summer, but 240-250 temps are not a big deal.
Unless I go to the track, I leave it in all the time and just suck air from the bottom.
Received 2,047 Likes
St. Jude Donor '13
Some companies make an easily-removable cover for the Z06 oil cooler- install it to keep oil temps up for street driving, remove it for track use.
air to oil cooler will cause your temps to rise quite slowly. the ZR1 water to oil cooler will warm the oil quickly and maintain it at a reasonable level.
I have a complete water to oil kit I would sell, All new, never used
IIRC, the integrated oil cooler was used only on the 2005 base cars (probably only on Z51 and maybe on Z51 stick shift), so OP needs to check carefully if he buys a different radiator.
In order to use the ZR1 style cooler (also used on early LS3 Camaros), you need an oil pan that will accept the mounting bolts. You will also need a return point on the radiator to accept the coolant coming from the oil cooler, or a T fitting to plumb it in.
Supporting Vendor
You could however use the Z06 or Z51 cooler as a transmission cooler if you made custom lines. We can assemble custom oil lines for you, if you take the measurements and know the lengths and fittings you need.
mikeCsix (02-28-2017)
I have done a DeWitts Rad w internal oil cooler, if you want to do your own, I have a B&M oil cooler and the Lingenfelter adapter for the block all you need is braided hose and ANI fittings and you can mount it anywhere, I was going to do a "rear mount" right where the filler plate would go, I have these parts for sale cheap.
Maybe someone else can better answer the question
timd38 (03-02-2017)
If you are not tracking the car, you don't need an EOC: a) your temps are not even close to being a problem and b) your temps will likely be less than ideal if you did put one in.
Save your $$$. You're good to go as is.
St. Jude Donor '13
If you just use your 'vette for driving to church on Sunday morning, you probably don't need an oil cooler. But for enthusiastic street driving, you likely need one. I've gotten our 2009 LS3 up to 260' rather quickly on twisty back roads many times, and hit over 290' several times in one mad blast through the back roads of Wisconsin. In both cases, I eased off the power and rpm to keep the oil from getting even hotter.
You can wait and see how your own driving style and conditions work out, maybe you won't need a cooler. But don't be surprised if you end up installing one.
My plan is to install the factory Z51 cooler and get a cover for it to use in cool weather. The best installation would be a big cooler with a thermostat, but that's more complication than I want.
