2006 Corvette A6 H/C/I LS2 Dyno
Old 03-06-2017, 09:25 PM
z06scentair
z06scentair's Avatar
Default 2006 Corvette A6 H/C/I LS2 Dyno
Been playng around with this car for close to a year. The car is a 2006 Corvette convertible LS2 with an A6 auto transmission.
The car has 2.56 rear gears and is a blast to drive.
Additions
- Comp cam 223/231 610/617 112
- Fast 102 unported with a stock 90mm LS2 T/B
- LS3 Injectors 41lb
- TFS 220's BTR untouched other than milled to 63cc for 11.1 comp
- Johnson 2110 Lifters
- Yank ss3600 stall
- 1 3/4 LG Headers and catted x pipe
- Corsa Exhaust.
This is a dyno dynamics dyno pull with 12.5 afr and 24 degrees of timing max. The converter was locked.
This was the first dyno a couple years back with the converter locked. This was all mods with the exception of the TFS 220'S
This was a second dyno last June which was more for Tranny tuning. The converter was unlocked and all modifications except TFS 220'S.
The following 2 users liked this post by z06scentair:
Brandon619 (03-10-2017), sallen619 (03-07-2017)
Old 03-10-2017, 09:25 AM
PCMusicGuy
PCMusicGuy's Avatar
Thanks for posting. I always like seeing LS2 A6 results.
Old 03-10-2017, 11:45 AM
myredhead1
myredhead1's Avatar
Nice! I bet the 3600 stall makes that thing a blast to drive!
Old 03-10-2017, 02:01 PM
Brandon619
Support Corvetteforum!
Brandon619's Avatar
Nice numbers, keep the LS2 alive!
Old 03-10-2017, 07:04 PM
z06scentair
The car is very fun to drive. With a larger cam I'm confident the car would have made closer to 500whp which is quite the feat for an auto.
Old 03-10-2017, 10:06 PM
xBoostx
xBoostx's Avatar
Nice numbers congrats should be a blast to drive enjoy it...
Thank you for posting and sharing it with us.
Old 03-10-2017, 11:39 PM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
Nice numbers there. Looks like that could be a 10 second car.
The locked vs unlocked converter appears to be ~30 HP difference with a 3600 stall. People don't understand that concept. I lost 17 HP on the dyno and dropped .15 seconds off my 1/4 mi time when I swapped from a 3600 to a 4000 stall.
Old 03-11-2017, 07:41 AM
z06scentair
The car with stock heads had run 7.13 @ 95mph
If I was racing the car I'd jump to a 4000 converter and swap the cam. It's mainly a street driven car. The 3600 is all I would ever want in its current usage.
It's amazing how far converter technology has improved over the years.
Thanks for the kind words.
To 2006 Corvette A6 H/C/I LS2 Dyno
Quick Reply: 2006 Corvette A6 H/C/I LS2 Dyno
