Are there any major problems with the new C6?
Not very many have been reported in the C6 General section. 2 or 3 people reported a problem with the F55 suspension, several couldn't play CDs above track 9, wiper on passenger side won't fold all the way back, several had distorted or no sound from speakers in driver's side door.
Originally Posted by CPT Z06
Just a recall on all the trannys in the Z51s, that's all.
Get Some!
Originally Posted by RedC6Coupe
I'm pretty sure that was just minor problem with noise when shifting into 5th gear on a limited consecutive number of 6-spd trannys. Haven't heard of a recall of delivered C6s.
They shut the plant down because of it. I do believe there is a recall also. I don't hang out in C6 general much, so there may be new info.
I have a major clutch problem.......... Gm tech field rep is supposed to check it out and i have sqeaking breaks..... one other member has voiced same brake problem
6 sp, z51
6 sp, z51
Not really a problem, but it's a real pain that the tuning software isn't ready yet Wait a few more months, and see what the guys start breaking. It shouldn't take long till somebody throws enough power at the car to grenade something
One member seems to be having problems with his C6. See the following post from C6 General Discussion.
http://forums.corvetteforum.com/showthread.php?t=924597
☠☣☢ Semper Ebrius ☢☣☠
No Problems In 3,500 Miles
Thanks, Chevy, for doing it right - the first time !!!!!!!!!!!!!!!!!!!!!!
Had a problem @150 miles with a loose damper on the crank... repairs took 2 weeks(no parts available) Had same problem @ 450 miles.. GM Powertrain eng. says they think they might be able to fix with a diamond embedded washer , maybe? but it will probably happen again! When it does they want to pull the engine!!!! Where do they get these guys? Had 2 more on order don't think I'll take them ... Should have waited on my GT-40!!!
