home made cold air intake
I am thinking of removing the air bridge and cutting an opening in the top of the shroud that funnels air to the radiator. If I then replace all the stock stuff,(air bridge and stock filter set up along with the cover that goes over the filter box) it looks to me that cold air would be sucked in through this area to the opening in the airbox that is closest to the airbridge. Perhaps I might hear from the flow mechanic's that are on the forum to hear if there would be a problems with this. I also have two K$N's coming, but since the purchase I have read a thread stating there are some flow tests showing the GM paper filters are better than the K$N's for $90. So sad for me if that's true,another few dollars down the drain. I'm not sure where the current filter gets its air as hood closure sure seems to be tight with this shield that is over the airfilter box. I imagine it's just sucking it out of the engine compartment. Realizing this is probably no big deal either way it just seems like it might be a cheap way to get cool air while I'm diving this thing. (Cold air to my brain anyway!) Thanks
So let me make sure I understand this. You are not going to have a airbridge what so ever? You might run into some problems with the MAF.
I was referring to removing the airbridge as a way to get a dremel tool or other type of saw in that area to open a vent for cold air access to the filters. The bridge removal would be for access only. Thanks, I think I will do this when the filters arrive
Check this link for C5 info on this mod. Click the PDF file for the cold air mod by dave68. I haven't seen the shroud on the C6 but it probably isn't very different from the C5.
I will take pics, then I will have to see if I can figure out how to post them so it will be awhile. I plan on using a dremel to open a slot in the shroud around the airintake for the radiator. I think I will place one just to the inside of each of the medial filter intakes. and perhaps some in the shroud just behind the filter box so it can draw cold air in under the cover that lays above the filter boxes. I will also look at the site noted in on of the responses to my note and see what there idea was. Just bought the Corsa Sport with dual 3.5 tips from Fichtner Chev total price $1023 this included shiping and no tax due, I thought that was good. Perhaps someone who is a better negotiator can do better?
I can't justify it at these prices. I went for it with a 997.2 GTS Cab, and I was going to keep it forever. But look and behold, the same dumbasses out there that can plow into your Taurus can also plow into your $150,000 ride. And it's never the same again, and you've lost your *** in resale. At 0-60 in the low 4s, if I do another 911 cab it's going to be a base model. What do I need a Cab to accelerate to 60 in 3.2 seconds for? Maybe I could go to the local dragstrip and beat up on some Camaros. In my Porsche GTS Cab. The only way I'd buy one is if I couldn't get a GT3 manual, and I had my heart set on a performance 911 for the track, I'd do a coupe in a performance build
But right now I'm pretty happy with my 981 Spyder. At least I will be, I think, once the new tires will be put on. That will balance. And not vibrate. Like the originals did. From the dealer, because it sat in a warehouse for 6 months.
OK, you guys aren't going to let this drop, are you? I'll weigh in.
Yes, I was trying to post on a Porsche forum I was looking at on Garage Talk. Somehow the screen scrolled into the Vette forum, apparently. Couldn't begin tell you how. Anyway, that's that. Although I do like the C7 a lot, spend a fair amount of time on the forum, and keep toying with the idea of buying one.
