C6 Vendor for Sale Exclusive forum for vendors to list C6 products, services and promotions.
New Lower Price! 6000k Low Beam Upgrade **$69.99**
Old 09-12-2013, 12:19 PM
0corvettemods1
Former Vendor
corvettemods1's Avatar
St. Jude Donor '12-'13
Default New Lower Price! 6000k Low Beam Upgrade **$69.99**
We have had countless requests by forum members to source a reasonably priced low beam replacement bulb to update the OEM HID bulbs in their C6's. As many of you notice, the 4300k HID's that are stock in C6's are not far from the yellow tinted appearance of a halogen bulb. It even becomes more evident when you see them side by side:
Before:
After:
Corvette Mods solution? 100% plug and play replacement bulbs that work off your stock wiring! No modifications whatsoever required.
These replacements are rated at 6000k, which is more of a clean white color over the stock 4300k yellow tinted lows.
You don't need any special skills to perform the swap either!
NEW LOW PRICE $69.99
Click here to order:
http://www.corvettemods.com/Corvette...de_p_5597.html
Pair these up with our switchback DRL LED's and HID Fog Light conversion kits for a perfect lighting upgrade
Click this link to go to our Fog HID conversion sale thread!
http://forums.corvetteforum.com/c6-p...77-99-a-3.html
corvettemods1 is offline
Old 11-12-2013, 06:38 AM
EuroRod
EuroRod's Avatar
I'm considering ordering the 8000k low beams and the 55w high beams.
My question: If I go with the brighter setup, is there any modification to the stock wiring, or, are these also plug n play?
A few years back I ordered (different vendor) some HD fog light bulbs, and the wattage increased to the point that the relay in the fuse box overheated, melted the female end inside the fuse box, and the entire box had to be replaced.
Should I stick with the 6000k bulbs to avoid a possible problem?
Thanks.
EuroRod is offline
Old 11-12-2013, 09:56 AM
0corvettemods1
Former Vendor
Thanks.
Color temp has no relation to power draw so if you want 8k go for it.
The ballasts we use won't cause any fuse issues, and the kit is all plug and play.
Old 11-12-2013, 12:00 PM
EuroRod
EuroRod's Avatar
Thanks. Will order later today.
EuroRod is offline
Old 07-21-2014, 03:22 PM
Yz Kid
Yz Kid's Avatar
how is the install on these? I keep hearing people say something about dropping the torx screws?
Yz Kid is offline
Old 07-21-2014, 03:31 PM
0corvettemods1
Former Vendor
Very simple and straight forward. If you use a magnetic screw driver you won't drop a thing!
Old 07-22-2014, 05:05 PM
Yz Kid
Yz Kid's Avatar
Where exactly could you "drop" the screw? in the headlight housing? Thanks!
Yz Kid is offline
Old 08-19-2014, 01:15 PM
Yz Kid
Yz Kid's Avatar
every time I turn my car on I hope I have a low beam out so I can justify getting these lol
Yz Kid is offline
Old 05-02-2015, 03:14 PM
0corvettemods1
Former Vendor
To New Lower Price! 6000k Low Beam Upgrade **$69.99**
Quick Reply: New Lower Price! 6000k Low Beam Upgrade **$69.99**
