PCV Oil Catch Cans - Two Chamber
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
PCV Oil Catch Cans
$129.99
They come in 4 colors. Red, Silver, Black and Blue
Our Oil Catch Cans are made of T-6061 Billet Aluminum. All the fittings on this unit are brass. The catch can is a two chamber design and comes with a changeable filter element for easy cleaning.
LSx engines all suffer from oil vapor blow by into the intake manifold under hard driving conditions. The two chamber design helps trap the oil vapor, and separates it into the second chamber for safe keeping. The benefit is that you keep your manifold from getting all gummed up and robbing you of horsepower.
PCV Oil Catch Can Link
Regards
Chip
Breather only
Hi Chip. I purchased two blue cans from you about a year ago. If it can be converted to a breather style cap catcher, do you sell just the breather portion? I'll also need to order another breather style catcher along with one breather portion only. please provide part number if available. Thanks..
I have the breather type catch can from you. Do I need to cap off the port at the throttle body since I don't have the throttle body return line connect from the PVC valve?
Regards
Chip
