New C6 Corvette Seat Rebuild Kit - in stock
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Seat foam and padding rebuild kit for the C6 Corvette - $39.95
Available here: http://www.southerncarparts.com/and-...it-p-3737.html
It is no secret that the seats of the C6 have a reputation for being less than satisfactory in the area of comfort and support.
The kit includes:
-Enough matierial to complete 1 seat
-Upholstery grade high density foam.
-Tough, wear-resistant ballistic nylon fabric.
-New, high quality, wire cover Jute Pad
-Zip ties to replace the metal hog rings.
-.25" thick high-density pad
-Detail step-by-step photo instructions.
Over the last year or so, a solid repair process has been developed and we want to share it with everyone. We wanted to see how it worked out in my car for a year and can say I feel its 100% better than OEM. There are two problems: The side bolsters from the factory do not have any support under them. So as you climb in/out of the seat, the outside bolster foam tears where it sits on the steel seat frame and quickly sags or goes flat. The steel wires in the center area cut into the foam and quickly cause the foam to sag and pinching around the hip area. I found this extremely uncomfortable after only 15 minutes.
This seat rebuild kit comes with all of the seat foam insert pieces necessary to provide the extra support needed to give your Corvette seats a more luxurious feel. If you want to improve the comfort of your Corvette without replacing the stock seats, this simple and affordable kit is a fantastic means by which you can do this. Easily installable at home, this kit provides the extra, high-density, strong and comfortable foam needed to give your Corvette seats extra support and cushion to help make your Corvette interior more luxurious and enjoyable. A great way to improve comfort and drivability quickly and affordably.
This kit corrects a flaw in the original seat design that leads to premature failure of the center and bolsters.
Working slowly, it takes about 1-2 hours. The detailed instructions with photos will take you through step by step. No special skill or tools required although you will need to purchase separately a can of spray glue for upholstery foam.
Supporting Vendor
These are still in stock and ready to ship!
Quick question, does the kit include just parts A, B, C, and D? I just bought my 2005 roadster a month ago and noticed the bottom of the seat cushion is really worn (prior owner must have been heavy). I am not talking about the leather but the cushion that is right under your butt.
Bought this a little over a year ago and already need to get another one. The foam used to cover the side bottom bolster is WEAK! It squishes within a year. Be forewarned.
I just bought another kit for the same seat I repaired a year ago.
JerriVette (05-10-2018)
Supporting Vendor
The kit includes:
