C6 Seat Rebuild Kits @ JWM- Fix those saggy seats today!
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Works with stock seat covers/foam or aftermarket replacements. If you're replacing your seat covers this kit is a must! The kit is also a great improvement for your stock seats.
Benefits of our kit
If you've ever taken your stock seat covers off you have noticed the seats side bolsters do not have any support under them. So as you climb in/out of the seat, the outside bolster foam tears where it contacts the steel seat frame and quickly sags or goes flat. The steel wires in the center area cut into the foam and quickly causes the foam to sag and pinching around the hip area.
The leather looks baggy and deep wrinkles appear. This is not a good look for your Vette! This seat repair kit corrects the seat design defect where there is no support under the side bolsters and the center wires slice into the seat foam.
Included in the kit is the material for 1 seat:
· High density Upholstery foam
· Tough, wear resistant Ballistic nylon fabric to repair the cut foam.
· .25 inch jute pad to make the seat firmer
· Zip ties to replace the metal hog rings.
· Detail step-by-step instructions with
No special tools are required. Spray glue like 3M Super #77 or #90 to attach the pieces will be needed. This is widely available at any home improvement or crafts store.
Our rebuild kit vs replacement foam kits
From our own research we've found the issue of the seat frame cutting to be caused by the area of the side bolsters in the lower seat area. Other kits do nothing to solve this issue. You can expect the same issue if you just purchase the seat foam kits.
We've also found in most C6s the seat foam is fine. They just need better support under the frame which our kit provides.
Stop riding around with no support! Order your kit today
Quick question,
I just bought my 2005 roadster and noticed the bottom of the drivers seat is very worn. Does your kit replace the foam beneath the leather seat cover (where your butt sits)?\Thanks,
Roger
Roger
Banned Scam/Spammer
No, this kit reinforces the oem foam. The replacement foam for the bottom is a GM part. This kit will help if you decide to replace that oem foam or keep it as is.
