C6 Corvette SCT Performance X4 Power Flash Programmer @ RPI Designs
Platinum Supporting Vendor
SCT's handheld automotive performance products increase your vehicle's horsepower, torque and throttle response by optimizing your vehicles PCM (engine management computer). Instead of optimizing your vehicle's PCM (engine management computer) for performance, SCT's Fuel Economy products optimize your vehicle's PCM for maximum fuel economy. High horsepower add-on's such as superchargers and nitrous oxide often require "custom tuning" in order to optimize your vehicle's PCM for such a large increase in horsepower and torque. SCT offers custom tunable products specifically designed for these types of applications and has a network of custom tuning dealers worldwide that can custom tune your vehicle for these types of performance modifications. SCT Pre-Loaded Tunes are designed for stock or lightly modified vehicles (cold air kits, exhaust systems, gear ratio changes etc.) Custom Tunes are created by one of SCT's custom tuning dealers worldwide and are specifically designed for your vehicle and its modifications. SCT's Custom Tuning dealers have complete control over your vehicles PCM using SCT's Advantage III Custom Tuning software and will optimize your vehicles performance for simple add-ons such as cold air kits or for high horsepower modifications such as superchargers, turbo kits or nitrous oxide.
For 1999 - 2014 GM Cars & Trucks , First and only cloud based tune delivery system that you can Switch on the fly and Power when you want it!! Increases Horsepower & Torque!
The X4 Power Flash arrives Pre-Loaded with DYNO Proven tune files that INCREASE HORSEPOWER and TORQUE! Programming your vehicle with one of SCT's pre-loaded tune files is as easy as 1-2-3. Simply plug the OBDII connector into your vehicle's OBDII port, select the pre-loaded tune file using the simple to navigate menu and within minutes the X4 programs your vehicle.
Easy to Read On Screen Data Monitoring
With a HUGE Backlit display, the SCT X4 Power Flash makes it EASY to read the Built-In Data Logging or Real Time Monitored Vehicle Data, view popular sensor data such as EGT, Air / Fuel Ratio or any other 0-5 Volt source!
Easy to Install & Easy Return To Stock
The X4 Power Flash device backs up your factory PCM program during installation should you ever need to return your vehicle to the stock PCM program. Restoring your vehicle to the stock PCM program is as easy as selecting Return to Stock from the device menu.
*This product is not legal for sale or use in California on pollution controlled motor vehicles
Increases your vehicles Horsepower, Torque, Throttle Response and even Fuel Mileage
Full Color Backlit LCD Display
Full Color LCD display for easy viewing, day or night.
Reads/Clears DTC Trouble Codes
Reads and clears diagnostic trouble codes quickly & easily, saving on expensive diagnostic fees.
Dual Analog Inputs
Monitor EGT temps, air-fuel ratio and other popular sensor data.
Installs Quickly & Easily
Installs in minutes via your vehicle's ODB-II port
User Adjustable Vehicle Parameters
Adjust for common performance bolt-ons such as Cold Air Kits, Exhaust Systems & Gears
Stores 10 Custom Tunes
Stores up to 10 custom tune files created by your local SCT Custom Tuning Dealer.
High Speed Datalogging / Monitoring
View & record your vehicles PCM data on the LCD screen or on your laptop.
Easy Restoration Back to Stock
The X4 Flash device backs up your factory PCM program during installation should you ever need to return your vehicle to the stock program. Restoring your vehicle to the stock PCM program is as easy as selecting "Return to Stock" from the device menu. With all SCT devices, once returned to stock, there is no footprint or trace of the tune in the vehicle's PCM.
Most Popular Vehicles Supported
Most popular GM vehicles supported 1999 to 2014 GM Cars and Trucks
USB Interface Cable Included
USB Interface Cable & Livelink Datalogging software included
Built-In Wifi for easy updates
Built-in Wifi allows you to easily attach to your local area wireless network to download device updates.
* Adjustable Options vary for each vehicle and are not available on all vehicles
Rear O2's Disabled
Disables the Rear O2s and eliminates CEL caused by rear O2 removal.
Fuel Injectors
Allows you to adjust for different sized fuel injectors.
CMCV Delete Plates
Allows you to disable the CMCV (Charge Motion Control Valve) in your vehicles PCM to prevent a Check Engine light and other issues associated with removing the CMCV plates in your vehicle.
Speed Limiter
Allows you to Remove, Increase or Decrease the vehicles speed limiter.
Idle Speed
Allows you to Increase or Decrease the vehicles idle speed.
Traction Control
Allows you to disable the vehicles Traction Control without using the button in the vehicle.
Spark Modification by RPM
Allows you to Add or Remove Timing by RPM Range. (0-2000)(2000-4000)(4000-8000)
WOT Fuel
Allows you to Add or Remove Fuel at Wide Open Throttle.
Shift Firmness Control
Allows you to change the transmissions shift pressure. Controls how firm the shifts will feel. * Vehicles with Automatic Transmissions ONLY
Axle Ratio
Allow you to set the axle ratio (gear ratio) to correct shift patterns and the speedometer on your vehicle.
Tire Size
Allows you to set the tire size to correct shift patterns and the speedometer on your vehicle.
Aftermarket Intake
Allows an aftermarket intake to be run on the vehicle without a Check Engine Light. For Intake Kits that require tuning, this will provide a selection of available intake kits.
Stores Stock Tune
Stores a true copy of your vehicle's stock file before programming. Used for warranty repairs and unlocking the programmer.
Supports Custom Tunes
Supports and holds custom tunes.
Fan Control
Lowers the Temperature at which the Fan turns on.
Idle Speed
Rev / RPM Limiter in Drive
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Drive
Rev / RPM Limiter Neutral
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Neutral
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
WOT Shift Points by Gear
Allows you to Increase or Decrease the Wide Open Throttle Shift points of each gear individually.
Item # 7416
Website Link : http://www.rpidesigns.com/shop/item....sh-programmer/
Dual Analog Inputs
Rear O2's Disabled
Fuel Injectors
CMCV Delete Plates
Speed Limiter
Idle Speed
Traction Control
WOT Fuel
Axle Ratio
Tire Size
Aftermarket Intake
Stores Stock Tune
Fan Control
Idle Speed
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
Item # 7416
__________________
