Brembo Brake Kits
Former Vendor
St. Jude Donor '13
Brembo Brake Kits
BREMBO PERFORMANCE BRAKE KITS
CHEVROLET CORVETTE C6 Z06 | GRAND SPORT FRONT 6-PISTON MONOBLOCK | 350X34 MM (13.8") | 2-PIECE DISCS TYPE III SLOTTED
Front kit contains:
v Two 6-piston monobloc calipers (Black, Red, Silver, or Yellow)
v Street performance brake pads
v Two 2-piece floating type III slotted rotors 13.8”/350mm diameter
v Front Goodridge stainless steel braided brake lines
v Adapter brackets
These 6-piston monobloc calipers have more brake torque using a wide annulus,kit uses the VERY high thermal 34mm thick rotor ring with 72 vanes.
This kit is excellent for everyday driving and HPDE events
http://www.xplosiveperformance.com/C...d-_p_2987.html
CORVETTE C6 FRONT 05-13 BREMBO RACING CALIPER (EXC ZO6/GS)
4-piston caliper, 2-piece, machined from casting
355x32x64a Type-5
The design of the new “race-ready” brake systems also meets or beats the requirements of numerous sanctioning bodies including SCCA, NASA, Grand-Am, BMWCCA and PCA, among others. Engineered for motorsports competition and dedicated track cars
These race systems include:
Ř New cast racing caliper with hard-anodized finish to improve resistance to thermal and mechanical stresses typical in the racing world. During the design stage, particular attention was paid to obtaining the best ratio of stiffness and weight reduction using special machining techniques.
Ř Brembo thermo tape on the caliper
Ř Type 3 & 5 groove assembled floating discs (from 328mm to 380mm) with high thermal capacity and heat dissipation
Ř Caliper brackets
Ř Steel braided brake lines
http://www.xplosiveperformance.com/C...S_p_3801.html#
CHEVROLET CORVETTE C6-PISTON MONOBLOCK | 355X32 MM (14") | 2-PIECE DISCS SLOTTED
BREMBO GT SYSTEMS
Front kit contains:
v Two 2-piece floating type II slotted rotors 14”/355mm diameter
v Adapter brackets
http://www.xplosiveperformance.com/C...ed_p_3331.html
Rear kits also available
