Wilwood C6 C5 Big Brake Front & Rear kit w/ 14" Rotors-$2299-Free Shipping
Supporting Vendor
St. Jude Donor '11
-Free Shipping!
-0% Financing for up to 1 Year!
-We accept ALL Car Care One Cards!
CLICK HERE TO PLACER YOUR ORDER!
Are you looking for a GREAT big brake upgrade for your C6 or C5 that won't break the bank? This is the kit for you! This kit comes with everything you need from Wilwood and TPS Motorsports! No other brake kit come close to giving you the performance of this kit for your money!
This great kit has everything you'll need to bolt them on your C5 or C6! This kit features large 6 piston front calipers with 14" Zinc Coated rotors and 4 piston rear calipers with 13" rotors. Calipers are NEW Wilwood Engineering parts and TPS Zinc Coated Rotors. Wilwood Street Brake Pads and DOT approved stainless steel brake lines are also included. Unlike other kits on the market our kit gives you the option to pick which rotor style, brake pads, and caliper you would like.
This is a direct bolt on system and comes complete with all needed parts.
* (2) Wilwood Aero6 6 Piston Front Calipers
* (2) Wilwood Superlite 4R 4 Piston Rear Calipers
* (2) 14" TPS Zinc Coated Cross Drilled Front Rotors|
* (2) 13" TPS Zinc Coated Cross Drilled Rear Rotors
* (1) Set Wilwood Street Front and Rear Brake Pads
* (1) Wilwood DOT Steel Braided Brake Lines.
* (3) Pints Motul Racing Brake Fluid.
Brake Rotor Option
*Slotted Only
*Cross Drilled
Zinc Rotor Color Option
*Slotted Only (Black only)
*Cross Drilled (Black, silver, or Gold)
________________________________________ ________________________________________ __
Wilwood Aero6 6-Piston Front Caliper
Aerolite 6R six piston radial mount front caliper kits add big brake stopping power and style to any 1997-2013 C5 or C6 Corvette! Aerolite 6R calipers incorporate race proven technology in a high strength forged triple bridge body design. They provide positive and confident pedal response that is matched to the OE master cylinder output and fully compatible with the ABS system. BP-20 dual-sport compound Smart Pads provide clean and quiet driving on the street, with improved friction and high temperature fade resistance for auto-cross and other sport driving applications.
Wilwood Superlite 4R Rear 4-piston Caliper
Superlite 4R calipers incorporate race proven technology in a high strength, center bridge reinforced forged body design. They provide positive and confident pedal response that is matched to the OE master cylinder output and fully compatible with the ABS system. BP-20 dual-sport compound Smart Pads provide clean and quiet driving on the street, with improved friction and high temperature fade resistance for auto-cross and other sport driving applications.
TPS 14" & 13" Zinc Coated Cross Drilled Rotor Set
TPS Performance Brake Rotors for Corvette's provide better stopping than the stock rotors and the performance look of cross drilled and plated rotors is an outstanding visual upgrade. These rotors are designed to eliminate out-gassing while minimizing stress cracks. These rotors are made by Centric the owner and maker of $3000 Stoptech brake. We then have them custom slotted and drilled to our specs.
Motul DOT 5.1 Brake Fluid- 3 Pack
Non-silicone based, long life and 100% synthetic, Dot 5.1 brake fluid conforms to the highest standards in brake fluid performance. DOT 5.1 is specially designed for Anti-Locking Brake Systems (ABS). With a high dry boiling point of 270anddeg;C and a high wet boiling point of 185anddeg;C, DOT 5.1 delivers the best brake performance. Non-silicone based and 100% synthetic fluid. DOT 5.1 is specially designed for Anti-Locking Brake Systems. High dry boiling point of 270anddeg;C. Wet boiling point of 185anddeg;C. DOT 5.1 delivers the best brake performance.
-Free Shipping!
Brake Rotor Option
*Slotted Only
*Cross Drilled
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...Mike Mak
Supporting Vendor
St. Jude Donor '11
Best Big Brake Kit Deal for your C5 & C6!
-0% Financing for up to 1 year!
No better Big Brake kit out there for the money! ONLY other big brake kit in this price range is the C6 Z06 kit... why get stock when you can have an upgrade!
Supporting Vendor
St. Jude Donor '11
