[Z06] How much does the LS7 weigh?
Originally Posted by IT L GO
Total Dressed Engine Weight - 497.2 lbs (226 kg)
IT L GO:
Are you sure about the weight? Where did you find that number? I checked on the LS1 dressed weight about 6 months ago, and I seem to remember 443lbs. Would the ls7 be that much more? Rods a little lighter, holds less oil if you don't count the separate resevoir, block and heads similar, crank probably a little more, rods and pistons a little less.
Originally Posted by drmotorhead
IT L GO:
