C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Octane boost
Old 10-11-2005, 01:26 AM
vegasdude
vegasdude's Avatar
Default Octane boost
What is the easiest way to get to 93 octane. Las Vegas does not carry it. And unless Rebel stations still carry 100 octane, because 76 stations have quit carrying it then I am out that solution. Does octane booster work as advertised?
Old 10-11-2005, 01:51 AM
RonnieSVT
RonnieSVT's Avatar
Because of the elevation in Las Vegas 91 octane should be fine.
Old 10-11-2005, 01:52 AM
vegasdude
vegasdude's Avatar
Cool, didn't realize that elevation played a part........learn something new every day............!!!!
Old 10-11-2005, 05:32 AM
Patrick McDaniel
Patrick McDaniel's Avatar
More info:
http://www.chevron.com/products/prod...i_octane.shtml
Old 10-11-2005, 10:17 AM
MitchAlsup
MitchAlsup's Avatar
Received 1,592 Likes on 784 Posts
As noted earlier, if 91 octane works, then it is easiest just to use pump gas. However, if you still need a little help:
Buy Tolulene and Xylene in 5 or 10 gallon containers and mix 50%/50% and then put into quart sized containers. Add one quart to each complete fillup. This should run about 20% of what octane boosters run a the parts stores.
Old 10-11-2005, 10:22 AM
C6Sixspeed
C6Sixspeed's Avatar
Thanks MitchAlsup!! Here in my town, 91 is all we can get and I'm almost at sea level.
Old 10-11-2005, 10:48 AM
DDSLT5
DDSLT5's Avatar
Torco is supposed to work great. jbsblownc5 (mostly found on the C5 FI section) is an official dealer, and can get you as much or little as you need.
Old 10-11-2005, 02:19 PM
WALLstAL
WALLstAL's Avatar
St. Jude Donor '05
One quart of Torco to a tank should yield approx. 94 Octane.
Old 10-11-2005, 02:25 PM
Yibbutkeen
Yibbutkeen's Avatar
I strongly disagree - the gas suppliers here in Rapid City claim the same thing - gas here is 85/87/91. My ZR-1 pings massively on 91. Fortunately there are a couple of stations with 94 available.
Old 10-11-2005, 02:35 PM
Mako7
Mako7's Avatar
Torco comes in little bottles--16 oz.? (and big drums). I thought you needed about 2 bottles per tank in the Z to get to 93.
Thanks for your thoughts!
Old 10-11-2005, 06:30 PM
SteveJ
SteveJ's Avatar
I'm not a chemist, but I know that major precautions are required when working with this stuff. Wear a charcoal filter breathing mask, and use rubber gloves, at least.
Old 10-11-2005, 06:33 PM
vegasdude
vegasdude's Avatar
Good Point!
Old 10-11-2005, 06:42 PM
jfreez
jfreez's Avatar
St. Jude Donor '07
I work in a lab and we deal with these chemicals, I am not sure about Tolulene but I am sure that Xylene absorbes directly thorough the skin. Xylene also will go through most laytex gloves in a matter of minutes.
Xylene is known to do significant liver dammage, so I say dont screw with it unless you know what you are doing.
we use nitrile gloves under a fume hood to avoid exposure.
Old 10-11-2005, 07:11 PM
WALLstAL
WALLstAL's Avatar
St. Jude Donor '05
How many ounces in a quart????????????
Old 10-11-2005, 11:42 PM
runutzzzzz
Support Corvetteforum!
runutzzzzz's Avatar
I also strongly disagree. Blew a motor in my TT NSX in AZ/NM going 185ish
Old 10-12-2005, 12:29 AM
Mako7
Mako7's Avatar
Point taken! Bottom line: in Cali we will go through a lot of Torco if we are not mixing 100--unless we run 91 all the time.
Old 10-12-2005, 12:35 AM
jbsblownc5
jbsblownc5's Avatar
2017 C5 of the Year Finalist
St. Jude Donor '08
Hey you lucky new Z06 owners!!
I have the best price for Torco on the Net!
One 32 oz can of Torco mixed with 18 gallons of 91 octane gas will put you right around 94 octane.
While the car may seem as though it runs ok on 91, just put some Torco in there on your next fill up and see what happens. I was at Buttonwillow raceway last weekend, and met 2 guys running 91 in their C5 Z06s. They each put Torco in their tanks and dropped a few seconds off their lap times. They both said they could feel the SOTP increase.
It's not that Torco or any other competent way of raising your octane will give you more HP, it's just that by running enough octane to keep you on the higher octane tables in the computer, you will have all the avaliable timing/HP.
I mixed 10 gallons of 91 octane with one 32 oz can of Torco and had Saybolt Labs in Carson do a octane test. The results were 96.5 octane!
Let me know if you guys need some,
JB
To Octane boost
Old 10-12-2005, 12:44 AM
vegasdude
vegasdude's Avatar
JB
I need some. Please email me at davea6@***.net so I can place my order........thanks.......
Old 10-12-2005, 01:01 AM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
You can order right off my site.
www.jbsblownc5.net
Thanks,
JB
Old 10-12-2005, 02:50 AM
vegasdude
vegasdude's Avatar
www.jbsblownc5.net
Thanks,
JB
Ordered and done!! Dave
Quick Reply: [Z06] Octane boost
