[Z06] clutch fluid restrictor
Lot of bad info out there on this subject. No one I know of ever cured pedal woes on a C5 by changing the MC line. Ditto the C6.
If you keep your clutch fluid clean on a C5 and C6, the pedal will behave normally.
On the C6Z, the pedal behaves badly on a drag strip launch if the clutch release is not extremely quick. Said another way...without slip.
The are usually a couple threads a week on this topic.
Ranger
Ranger
Originally Posted by patton
oops not my bad its in the line near the master just drill it out 1/8 bit about 1 inch till it goes in free. no more please release me at 7 grand
C6Z owners who keep their clutch fluid clean are not having any trouble with their pedal behavior at high rpm. I've got 33 passes in mine, zero pedal issues on the shifts.
Ranger
restrictors
Ranger
Ranger
Flow restrictors are usually not installed in the brake line. Sometimes in the master cylinder outlet port. Some outlet ports have a check valve which will hold a little pressure in the system down stream of the master cylinder ....maybe this is what is being refered to...???
Is there a bleed screw at the slave cylinder for the clutch? Advise
St. Jude Donor '09
www.installuniversity.com go to INSTALL then TRANSMISSION. I'M not trying to be a pain about this it's just me thinking i read about this 5 yrs. ago
Originally Posted by cbgpe
Ranger
Bunch of folks hoped that installing a restrictor-less line would solve their clutch pedal woes. Some vendors custom-made and sold these restrictor-less lines. And owners tried them on C5s. Unofrtunately, didn't solve their clutch pedal woes.
BTW, hoping you'll follow-up on the dead-battery thread you started.
Ranger
cbgpe , Believe Patton is talking about a restriction that some parties report exists in the clutch hydraulic line from the master to the actuator (slave). It's a carry-over thought from F-bodies.
Ranger
Ranger
DBS went away as qickly as it came. Could be a key fob stored too close to the car... will keep you posted on that one....
Ranger
cbgpe, That would be a good outcome. If you get a chance to post that again on that dangling thread, t'would be good.
Ranger
