[Z06] What's the fastest trap speed in a Z06 so far?
I know some of these cars are dynoing over 550 rwhp, so I was expecting to find traps over 130 mph for the modded cars on drag radials. But the fastest I've been able to find is 129.
Has anyone had a higher mph than that yet? Thanks in advance.
127.55 and 127.56 on back-to-back passes on DRs at a DA of 1600'-1800'
127.53 and 127.52 on back-to-back passes on stock tires at a DA of 300'
Several modded 2006 Z06s have cracked through 130. But most of them aren't making passes in the summer's heat. But by late-Fall, several will have made enough passes to see more impressive trap speeds. Gotta keep in mind that some of those folks are still looking for the right aftermarket clutch.
Ranger
Mine has headers and a tune and I could only manage 122 in the 100 degree heat last friday. At least it was an 11.9 though. The newer trans ams and 350Zs couldn't even run 100. The Zs were in the high 80s low 90s so the heat has a huge effect.
But, I have seen 127 from a 450 rwhp Z06 and a 130 from a 500 rwhp Z06.
I am guessing with 550 rwhp (Cam, bolts on, tune) we can see 135 mph traps. Not bad for NA, original, all motor power..
Originally Posted by Zlicious
I haven't seen any trap speeds yet coming from a 550 rwhp Z06.
