C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
How do you remove rear fender brake ducts,06 Z06?
You have to remove the rear fender wells and then un-snap the duct latches from inside the fender well area. It's a PITA to un-snap them, but it can be done with the right screwdrivers and a little persistince. (Removing the rear wheels is also required.)
They clip in on the inside and outside. To keep from removing the fender wells to access them, I slid a 3x5 card in and worked them until the snaps rode over the card, then they popped out with a minimum or trouble.
