C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Bleed screw at the clutch slave cylinder?
Old 10-08-2006, 12:12 PM
cbgpe
Support Corvetteforum!
cbgpe's Avatar
Default Bleed screw at the clutch slave cylinder?
Does anyone know if there is a bleed screw under the car at the clutch slave cylinder to drain and change ALL the fluid. Changing the reservior fluid seem like only a 1/2 measure at best.I have done it many times but it never stays clean !
Old 10-08-2006, 08:30 PM
*C7*
*C7*'s Avatar
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I would think it is like the C5, and yes you can bleed or flush it from under the car but it is a real PIA. You have to remove the tunnel plate and search for the bleeder as you can not see it.
I put a remote bleeder on my C5 and if I ever have the clutch out of my Z06 I will do the same..
Old 10-09-2006, 11:43 PM
mousecatcher
mousecatcher's Avatar
I plan to replace the tunnel plate on my z06 the next weekend I'm free. Is it worthwhile to install an extension then, or is it much more involved than just the tunnel plate?
To Bleed screw at the clutch slave cylinder?
Quick Reply: [Z06] Bleed screw at the clutch slave cylinder?
