C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 1st time in a long time
Old 11-13-2006, 09:14 PM
JWGJR
JWGJR's Avatar
Default 1st time in a long time
It's been 4 years since I last drag raced my 03 Z06.
Last saturday took the 07 Z06 (bone stock on stock tires) to Cecil County Dragway for a test and tune. Weather was average - warmed up to about 70F.
Pretty crowded and I got 3 runs in. Followed Rangers recommendations on tire pressure, clutch release, water temps, etc.
I was pretty conservative. Came out at 2000 rpm, fast release of clutch followed by throttle. Car locked up, bogged and I just let the motor do the work.
I didn't get any wheel hop in first gear but did have a brief amount of wheel hop/tire slip during shift into 2nd and also may have had some minor amount of tire slip with shift into 3rd. It was hard to really tell.
I also lift throttle on gear changes but I definitely stomp the gas to the floor after shifting - and I think this triggered TM. It is really counter intuitive to shift without applying throttle as quickly as possible. I was shifting pretty close to 7000 rpm without hitting the limiter.
My first run was 11.84s @121.0 mph with a 1.9 60ft. I was pretty happy as this was better than my best run in the C5Z after 60 passes (11.93 @ 117.5 with CAI and BFG's).
Second run I did 2nd gear burnout which worked well - tires heated quickly and didn't have to rev over 5000rpm. Came out at 2200 rpm. This was my best run.
60 ft 1.86 s
330ft 5.081 s
1/8 7.659 s @ 95.97 MPH
1000 ft 9.864 s
1/4 11.709 s @ 122.85 mph
Came out at 2500 rpm on third run and overspun and slowed to 11.9s with 2.0 60 ft.
I'm wondering if anyone can tell how/if TM affected my run? 1/8 mile mph seems low but car seemed to pull strong in 3rd.
Thanks in advance for any comments/suggestions. I feel like I need to practice throttle application at the start and shifts to avoid TM to lower my ET's (as well as my shifting and take-off and another 40-50 runs!).
Old 11-13-2006, 09:42 PM
TetraU
TetraU's Avatar
Pretty damn good driving considering it's your first time out with the car. Keep this up you will be banned from the track soon. Good job!
Quick Reply: [Z06] 1st time in a long time
