[Z06] Codes
Codes
Check Engine lighted
I Connected Efi Scan Tool
I`ve got CODES
P0036
P0036
P0713
Corrected, the light has gone...In some Miles Check Engine lighted again.
Advice what to do?
I`ve got CODES
P0036
P0036
P0713
Advice what to do?
Not sure - maybe someone else can provide more information.
Would start by checking your fluid levels of coolant and Transmission fluid.
Have you noticed any leaks under the car?
Well, I'm certainly no expert, but you to give you a bump and some possiblities... I see you have had some "work" done to the car so one possibility could be a wire (or wires) have come loose or come in contact with something hot (headers) and opened up. Both sets of wires I believe go from the ECM to the area of the tunnel (O2 after the CAT, and the trans in the back). Of course the sensors could have gone bad, but the wires could have come loose or been damaged (by heat or abrasion). In any case, since it's the secondary O2 sensor, it would seem relativly safe to drive for a while. If you had some ramps handy a quick look-see might reveal something. Good luck, and I hope you find it....
DTC P0036. HO2S Heater Control Circuit Bank 1 Sensor
If you do not find any visual problem (shorted or damaged wiring) , I will call Ligenfelter they should be able to help you. good luck
