[Z06] Replace Brake Fluid Like Clutch Fluid?
Can I replace my brake fluid as Ranger has suggested we do with our clutch fluid? Seems like it would be a no brainer to keep the brake fluid clean, right? Or, would I just get air into the system?
A power bleeder is the best way to change brake fluid. Power bleeders completely flush the system by either forcing fluid through the system under pressure, or by sucking fluid through the system from the bottom. I have both types of bleeders and they both work well. Its the only way to flush the system. Just let it run till the fluid runs clear...
Another option is speed bleeders. You can do a search and find their site. You replace your bleeder valves at the calipers. They have a one way valve built into them so you can attach a silicon hose, crack them and pump fluid through and they will not allow air to come back in when brake pedal is released. That way you can change the fluid in your master cylinder and pump though fresh fluid. I remove the master cylinder cap and clean any condensation off, add some new fluid and bleed fluid from a different caliper every time I service the car. It stays clean throughout the system that way. The part number for the stainless speed bleeders is SB1010S, the Z06 takes 8 of them.
JJ
JJ
If you're not tracking the car, the pad replacement interval is probably sufficient for brake fluid changes. If you're tracking the car, you need to be a lot more rigorous for all fluids and maintenance items.
Brake fluid doesn't circulate through the reservoir like the clutch fluid, so the RANGER clutch method wouldn't be very effective when used on brakes. You really want to get the burned fluid out of the calipers, so you need to bleed through the bleed valves on all 4 wheels.
JJ...is that a GM p/n?
JJ
JJ
St. Jude Donor '08
I haven't done the clutch fluid. Could you let me know if there is a good link to see the process?
I bleed the brakes last weekend. I used a synthetic DOT 3/4 compatible brake fluid as I've heard the DOT 3 will boil on track days. Unfortunately I didn't use a speed bleeder, just a hose over the fittings, one wheel at a time. Definitely not the way to go, very messy!
