[Z06] Metal on metal sound from right rear wheel
I am hearing a metal on metal sound when I make a turn from my right rear wheel well. Is it the wheel touching some surface or the disc rubbing on the disc pads? Has anyone else experienced this or know the remedy? I checked my lug nuts to see if they were loose, but they were tight. When I had my new muffler installed the entire rear end was dropped so the clearances would work. Could that be the issue or should I just take it in for a warranty check at the dealer? Thanks.
Don't know if this could be causal, but have you checked your axle nuts?
Back only - 118 ft lbs.
1 5/16 or 33mm or 34mm deep well required.
Good luck,
Chris
Good luck,
Chris
