[Z06] Street Legal???
Street Legal???
I talked with a few tuners (Lingenfelter included) and I might be naive but if I get a car back with the engine light on and the PCM kicking up codes for the cats because of long tubes and high flow cats how am I gonna have it pass emissions???????????
Greg
Greg
To be exact, it is illegal to replace OEM cats with anything but OEM cats and ONLY if they fail. Yes, this technically makes all headers, "high flow cats" or not, illegal.
St. Jude Donor '08
or to move then from their origional position. After maket cats are fine. All long tube headers move the cats to a more distant location so that in itself is illegal.
I would be surprised if there is ANY state that has smog rules that would pass a car with an illuminated CEL - end of story. In many (most?) states the DTC's would not be noticed.
Premium Supporting Vendor
It doesn't matter what state you are in. It is illegal for a shop to remove the factory catalytic converter. Period. This is a federal law. It doesn't matter if you replace it with an aftermaket catalytic converter. It doesn't matter if it passes smog in the state you are in afterwards. Simply by removing the catalyst the shop is breaking the law and subject to a $25,000 fine and the possible shutdown of their business.
Given that and if the statement in another post above that they cannot be "moved" is also true, are there any sets of headers available that are "street legal" for the C6 Z06?
- Mark
Not at the moment. We need headers with a CARB (California Air Resource Board) EO number(Executive Order).
Lingenfelter told me that the check engine light will be on and codes will kick up.
I know Florida where all of my cars were registered before,
has NO INSPECTION & NO EMISSIONS.
I'm going to change my plates to FLA again.
Greg
Greg
My LPE car had a CEL on after installing the headers. The aftermarket cats don't generate enough heat and spark the code. LPE will not delete the codes for you. You have to do that yourself. I used a friendly shop's TECH 2 and deleted the code.
If a Lingenfelter representative did indeed tell you this, then it's worse over there than I had gathered.
I can tell you, with experience on MULTIPLE C6's, that there is no need for the codes you mentioned. The codes/lights can all be disabled (through the computer)!
I recommend that you find a different tuner for your mods.
If you delete the code it will just come back the next time the PCM runs the test. You have to use LS2edit or HPtuners to turn the diagnostic process off for that DTC. By doing this you are defeating an emissions control device and once again, illegal.
Didn't realize this! Thanks. I guess I'm gonna have to find a way to turn it off then! Although, it's been quite a while now and it hasn't come back on?????
If telling someone that the headers they installed will trip a code makes them a bad tuner................then all the tuners on this board are bad tuners by your math.
Does this gather?
I found out from LPE that all of their packages come back WITHOUT any check engine light or codes.
The Z06 is the only one that does and it can be taken care of with software you can do yourself, because if "they" do it it's illegal.
Greg
Greg
