[Z06] 2nd to 3rd shift problem.
I have a 2006 Z. This has happened to me a couple of time now. I will be getting on it and shifting from 2nd to 3rd, and the shifter will be in third gear slot. when I let the clutch out its like its in nutural. Just curious if any one else has had this happen to them. I don't know if somthing might be wrong with the trans, or just my shifting. Probably my shifting. Car has 2700 miles, Thanks for any Info.
St. Jude Donor '08-'09
I've got an '07 Z and was having a problem going from 2nd to 3rd when doing high rpm shifts.
My situation was I couldn't find 3rd. The shifter would go up, but not in any gear
Thanks to the forum, I figured out it was my hand position on the shifter. I was using my fingers instead of the palm to push it into 3rd.
Once I mastered the hand position, haven't had a problem.
augydog
augydog
I had the same problem with my 05 C6. I remember that GM had a notice about this problem. If I remember correctly it also effected the Cad that had 6sp trans. Los Gatos Chevrolet said they knew nothing about it until I pulled out the bulletin. G.M. ended up buying the car back as a lemon so I did not need to do anything with it. The reason it was a lemon was it was in the shop for about 50 days in the first 6 months because of the fuel sending unit, trans and electrical.
augydog
augydog
St. Jude Donor '09
more miles on the tranny will help. i use an open palm with slight psi. to the right and a LOT of psi foward. i speed shift [WOT no lift on gas quick clutch] the shifter is very capable. relax,make sure car is hot
Thanks for the tips everybody. After it happened the other day I tried the no lift without any problems, but I have read somewhere that the computer pulls power when you shift like that. I don't no, seemed to do fine to me.
St. Jude Donor '09
it pulls timing like crazy. its called torque management. i had mine adjusted to min. and if ya thought the car was mean before it gets down right nasty,its not meant for weekenders,or z,s with pretty boy tires
augydog
augydog
Me too same problem fixed by proper shifting...
