[Z06] Dot 3 vs Dot 4 brake/clutch fluid ?
I'm having a hard time finding some Dot 4 brake/clutch fluid at any of my local Chevy parts departments...The owners/manual says to use Dot 4 and as I'm going to a track rental soon, I wanted to be prepared for clutch fluid changes...So I guess the question is are you guys using Dot 3 or Dot 4??? - Thanks in advance...
Greg
Greg
I bought MOTUL 600 RBF BRAKE FLUID from Circle Track Supply, Inc. It was about $100 for a six-pack including shipping.
Have fun at the track but be safe!
Jim
Jim
Thanks, I found some Motul local...
Greg
Greg
Prestone DOT4 synthetic brake fluid at Walmart for about $2.50. They also have the 2 stroke mixing syringe for like $4.00. I'm sure the MOTUL brand is good but the Prestone is readily available.
Thanks guys...
Greg
Greg
Dot 4 is a dot 4 is a dot 4...So I'm told...
Greg
Greg
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
They are not all created equal.
BRAKE FLUID COMPARISON CHART
Brand Wet Boiling Point Dry Boiling Point
Castrol SRF 518°F 590°F
Motul RBF600 420°F 593°F
Wilwood EXP 600 417°F 626°F
AP-600 410°F 572°F
Brembo LCF 600 399°F 600°F
ATE-Super Blue 392°F 536°F
Valvoline 333°F 513°F
Castrol LMA 311°F 446°F
Ford HD 290°F 550°F
Wilwood 570 284°F 570°F
PFC-Z rated 284°F 550°F
AP-550 284°F 550°F
AP-600 410°F 572°F
Ford HD 290°F 550°F
AP-550 284°F 550°F
Ok, here's kinda a side question about DOT4....
I bought some DOT4 for my car and a few days before I was going to flush the system out, I noticed the label and it said "not recommended for use in ABS equipped cars"
I bought SSBC brand. Is that just a "covering our a$$es" line, or is that really on their for a reason?
I never put the fluid in, so if it's nothing to worry about... I'd like to know so I don't have the fluid here as a waste of money.
Also.. didn't want to thread jack.
Lammo question from first time stick owner.........
.......Which ever DOT 4 fluid you pick goes in Brake and Clutch, right?
If so the ATE Super Blue (which I always used in my C5 brakes) is OK??
I would get the Amber as to not draw attention at the dealership
DH
DH
Actually are cars come from the factory with Super DOT-4 clutch fluid. It's a little different than regular DOT-4. To keep things simple, I get the original GM parts number fluids listed in the owners manual, from Gene Cully's web site.
