C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Rear Creak TSB?
Old 08-18-2008, 05:55 PM
MatthewR
MatthewR's Avatar
Default Rear Creak TSB?
Can anyone shed some light on this TSB? I have a creaking noise from the back area --could swear it is the hatch latch but the dealer's efforts have been unsuccessful. Saw this from a list of technical service bulletins someone just posted.
Matthew
SERVICE BULLETIN:4678 NHTSA ITEM NUMBER:10023737 MFG Bulletin Date: 20071201
Component: UNKNOWN OR OTHER
Bulletin Summary: POP OR CREAK NOISE FROM REAR OF VEHICLE BEHIND THE SEATS. *NJ Date added to datbase: 20080129
Old 08-19-2008, 10:08 AM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
i would love to know, my 08 does the samething. i swore it was the hatch so i took to the dealer no fix
Old 08-19-2008, 10:32 AM
GotMoJo
GotMoJo's Avatar
I'd like to know as well.
Old 08-19-2008, 10:37 AM
jswatek
jswatek's Avatar
Interesting! I've been trying to figure it out for 2 years!
Old 08-19-2008, 10:58 AM
DSteck
DSteck's Avatar
Mine does it when I hit a bump, and it seems to come from the right rear. I'm staying tuned to this.
Old 08-19-2008, 11:00 AM
imp zog
imp zog's Avatar
Is it a creak when you first start moving or hit a bump? I haven't had it in the C6 Z06 (yet), but the C5 did it all the time, and it turned out to be the rear sway bar, creaking in the bushings that attach it to the crossmemember (not the endlinks). Apply some bushing-safe lubricant to them, and see if that makes the noise go away, it worked for me.
imp.
Old 08-20-2008, 05:39 PM
MatthewR
MatthewR's Avatar
Default Any info on the TSB?
I hear a loud creak/pop when I traverse a steep grade such as the entrance/exit to a driveway. Sounds like the hatch is shifting positions. Dealer first removed/messed around w/ the shims at the lock area. Then, replaced the rear hatch hinges. Still have the noise and it is annoying.
Anyone know what that TSB identified above concerns?
Old 08-20-2008, 08:26 PM
clogan
clogan's Avatar
I've got it too...pesky, isn't it!
CL
Old 08-20-2008, 08:27 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
CL
Old 08-21-2008, 07:56 AM
mikemote
mikemote's Avatar
Same thing 2008 but mine just started,had the car for over a year.That
crossmember statement sounds good. I'm following this one.
Old 08-21-2008, 09:08 AM
jonDough
7th Gear
jonDough's Avatar
Just picked up my 09 and mine has it too. Found this thread which may be the issue.
http://forums.corvetteforum.com/show....php?t=1867457
_JD_
Old 08-21-2008, 09:19 AM
GotMoJo
GotMoJo's Avatar
I addressed this to C4C5specialist over at Corvette Mechanic and he stated this is no longer in GM's data base and is a non-issue.
I notice it when entering or exiting my driveway. I would hate to think that there is enough frame flex to cause the hatch to move around.
I'm going to try an experiment and leave the hatch open a slight amount and see if I still hear it. I'll report back with my findings.
Old 08-21-2008, 03:42 PM
GotMoJo
GotMoJo's Avatar
In case anyone's interested, it doesn't creak with the hatch lifted.
It's hard to believe the frame flexes enough to allow this. Maybe one of the thick tunnel plates would cure this problem.
Old 08-21-2008, 07:02 PM
MatthewR
MatthewR's Avatar
Default Mojo: Tunnel Plate
doesn't help as I have that installed on mine.
Old 08-22-2008, 06:57 PM
jonDough
7th Gear
jonDough's Avatar
Found out mine is a rattle coming from right above the exhaust. There is a metal piece that holds the plastic away from the exhaust. The bolt holding this metal piece is not there on the left side but it is on the right. Going to stop by a dealership tomorrow and see if they have the bolt in stock. Hopefully this fixes the problem. I will take pics if anyone wants to see.
_JD_
Old 09-11-2008, 10:33 PM
car2fast4you
car2fast4you's Avatar
My 08 with 5K miles just started "creaking" from somewhere in the trunk area last week.
It does it quite often when backing out of the driveway, or just when I start to pull forward.
At first, I thought it was related to the 2 struts that support the hatch.
I still think the sound may be coming from there.
Tonight, I added dialectric silicone grease to the following areas:
1. The rubber boot that covers the electrical connection on the bottom of the hatch struts. They're kinda sqeeky if you twist them.
2. The seals around the perimeter of the hatch. I just recently cleaned these off....perhaps this was the issue?
3. The 4 rubber shoes that the hatch rests on.
It's supposed to rain tomorrow & Saturday, so, I may not drive it until Sunday.
I'll let you know then if this solved my problem.
I do have one more thought....
Whenever I have the top stored in back, it squeeks quite a bit.
I believe it's coming from the front plastic pylons that the top snaps into.
Those "pylons", for the lack of a better term, squeek loudly when I push on them or twist them with my hand.
I wasn't able to figure out how they come off - so, I wasn't able to mess with them.
Perhaps the creaking is originating at those points?
Just some ideas.
I'll keep you posted.
Old 09-12-2008, 12:22 AM
Joezone914
Joezone914's Avatar
Mine has been doing it since I got it. I have removed the 2 shims and applied silicone to the seal where lid meets the car all the way around and it is much better but must re-apply once a month.
To Rear Creak TSB?
Old 09-12-2008, 12:30 AM
dfinke23
Support Corvetteforum!
dfinke23's Avatar
Old 09-12-2008, 12:46 AM
QQB825
QQB825's Avatar
i get the same thing. ~3500 miles on the clock.
Old 09-12-2008, 08:37 AM
teking
teking's Avatar
I have the creak/pop only when I first start off. Been to the dealer once about it and they didn't help for crap.
I think it's probably the suspension bushings or the torque on the rear axle nuts.
Quick Reply: [Z06] Rear Creak TSB?
