[Z06] 2008 Z06 Upgrade to Nav radio
Cruising
Have a base 2008 1LZ w/o Nav Z06. I wanted to put GM Nav radio (from 08 Z06) in, can this be done as just a swap or do I need new cables, antennae, etc. Is everything there or does it all need to be added? Has anyone done? Comments?
While it's true you can do it, it will not work completely unless you have a Bose system. So save yourself the time, money and trouble and don't even attempt it (at any price)
Cruising
Thanks for your help and information. Regarding GPS antenna, I know there is a combo GPS/Cellular for Onstar under front dashpad. Where do they locate GPS antenna for NAV radio? I have discovered all the other antennae locations, AM/FM diversity(2), XM diversity(2), Onstar...now this is the last location.
Cruising
Thank you everyone for your comments and advice, very insightful. I understand the addition of GPS antenna, but does anyone know if the existing cabling will just connect to radio? (Plug n Play).
Search the audio section. I think you do need the Bose system. I had the base system and there was only one connector when I installed the aftermarket NAV. I just removed an OEM nav from a 2008 vette and there was the XM conection which you don't need to plug in and two others as well as the gps antanae. You may install a new GPS antanae and sit it on top of the AC duct. It works fine there. Go with the Kenwood.
Everything you need is there to plug in except the antenna which mounts above and to the left of the nav, but if you don't have Bose, why do you want to install the factory nav?
a better question is why would you want the factory nav or bose at all? both are marginal at best.
First thing I do in any car I buy is rip out the bose crap and install excellent aftermarket. I still have my Stock 08 Z06 navigation... i rarely use it anyway and have much more important things to spend 1000 dollars on (like nitto invo tires) lol
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
It is plug and play. Order the GPS antenna and the microphone for the "A" pillar and it all works great. The wire harness for the mic is already in the "A" pillar trim. A quick re-program with a Tech II and you are on the road. Did it in mine and it took all of 45 minutes for everything.
I'm with Toxin in one respect, I strongly suggest you consider how badly you want that GM nav system before you go to the effort and expense. I won't bore you with my take-aways for the system, but there are a few threads that outline the downsides. If I had it to do over, I'd have the 6-disk, including MP3 port and a Garmin nav instead of this system. Take a few minutes and check 'em out before making your final decision and take a ride in a buddies Vette if you can.
Just get an aftermarket unit, Kennwood seems to be the one of choice.
Cruising
First of all I would like to thank all of you for your candid and accurate insights and comments. I have now used the factory system in another Z06, and do not like a lot of features that are part of the system. I am re-thinking my original intentions...thanks to everyones help, time and thoughts.
Owning the Z06 has been a lot of fun, but being part of this forum adds a new dimension to being a Corvette owner. Thank you everyone again.
Jim
Jim
I have the 2LZ in my 08 Z. NAV is garbage and I'm a Garmin GPS NAV distributor...so guess what...today I popped a Garmin Nuvi 760 in and used its FM modulator to play through the radio. The Nuvi is sitting on the windshield next to the mirror and now I have Bluetooth wireless hands-free connection to my phone through the Nuvi, a full featured MP3 player and a traffic receiver, using the Bose as the speaker. It sounds amazing for an FM modulated signal; loud and clear with virtually no FM interference and I can't hear the small amount of hiss, because the Vette is so damn noisy anyway LMAO.
Garmin's NAV blows away the GM NAV...for about $400.00 bucks and takes minutes to setup and install. I will install the 12V wiring through the roofliner/A-pilar to hide it and have it turn on and off through ignition. It would be cool if it could be an in-dash install, but this works beautifully and you CAN enter navigation commands while driving, unlike the factory NAV, which needs $$$$ to get around that. I will add an Aux in adapter to get even better sound quality...but that isn't really all that necessary...I'm just **** about it LOL.
Factory NAV blows -- Go Garmin and get a truckload of useful features; you won't regret it!
You can also snap the Garmin out of its cradle to use in another vehicle whenever you like.
More and more vehicles are now being equipped with Garmin portable NAV units instead of the factory installed overpriced garbage...
Wait till you have to buy the map updates for the GM Nav...LOL
