C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 2008 Z06 may be a flaw in some tranny's
Old 03-21-2011, 04:40 PM
  #221
PatriotZ
PatriotZ's Avatar
Location: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
[QUOTE=Bill Dearborn;1577080841] If it ain't broke don't fix it. A little bumping on a cold shift doesn't indicate or even come close to indicating a problem with a transmission. I started at the beginning of this thread and I think the OP was a victim of being **** and complaining about a non problem, which got him involved in a violation of the "if it ain't broke, don't fix it" law.
Bill[
I was also going under the ".....if it ain't broken rule also..... for a few months of grinding fifth gear....but as others have said...what's to worry if it is a warranty.....now I can feel relieved and get on with it....and hopefully with no further grinding or bumping.
Originally Posted by FastestBusaAround
I had my 5th-6th gears and synchros changed under warranty because of a 5th gear grinding as well...
I just came from my dealer and they are replacing my fifth gear and syncro....oither gears were OK.
Warranty item........ and life is good
Old 03-22-2011, 09:11 AM
  #222
letsrollmike
letsrollmike's Avatar
I must have been blessed with a good one. I have no issues. 21k miles.
Old 03-31-2011, 01:15 AM
  #223
Hercules Rockefeller
Hercules Rockefeller's Avatar
My '08 has been grinding when performing a high RPM shift from 1st to 2nd since the day I bought it. Hundreds of other people have had this problem too, and it's been going on for YEARS. Has anyone figured out what the problem is, or do we just have to live with defective transmissions forever???
Old 03-31-2011, 10:59 AM
  #224
Jeffthunbird
Jeffthunbird's Avatar
It appears that this should be a "Sticky" thread.
Old 03-31-2011, 08:25 PM
  #225
tkr
Support Corvetteforum!
tkr's Avatar
Mine is a 08 and I get a little metallic growl on occassion taking off in 1st. I believe this is clutch related.
Old 07-08-2011, 04:19 AM
  #226
JeremyGSU
JeremyGSU's Avatar
Originally Posted by Mopar Jimmy
If you in the market and are concered about it stay away from an 08 Z, the issue was fixed in 2009, nor did it exist with the battle tested T-56 trannyd used in the 06 and 07 Zs.
What issues are you referring to as fixed in '09? If it's the notching transmission/grinding issue there are a number of guys in this thread with '09s having that problem. So not sure what is "fixed".
Old 07-08-2011, 07:32 AM
  #227
Keiffer
Keiffer's Avatar
My 07 has been at the dealer for 3 weeks with them waiting on t56 parts or a new tr6060. The mechanic said my tranny was hot. I guess that it had a burn in it. I find it hard to believe that dealers can't get parts or a new tranny because none are available. So my wait continues
Old 03-26-2012, 11:33 AM
  #228
valet_devil
valet_devil's Avatar
Is it reasonable to expect a low to mid mileage '08 would have already had this issue come up and corrected by an original owner if it were going to happen? I am in the market for an '08Z.
I have test drove two looking for this issue. Is it only apparent at a high RPM shift or can you feel it just rowing through the gears while the car is off?
Old 03-26-2012, 12:31 PM
  #229
bass mechanic
bass mechanic's Avatar
my 2012 has the same issue, i would consider it normal as my 2008 was exactly the same. i would not put any concern on this subject.
it seems only apparent when the trans is cold and your driving normally.
i think by the time most people are ready to romp on the car, they have already gotten the engine to operating temp and the issue is gone by then.
fyi i have heard of several people changing out the manual trans fluid to something different with good results. i would do a search for that and plan to replace it if you think yours has any issues.
Old 03-26-2012, 03:27 PM
  #230
m.whitmell
m.whitmell's Avatar
Is there an easy visual clue to seeing if I have a T56 or a TR6060 in my 08 Z06. I had it in the other day to install my ackrapovic exhaust in a Corvette performance shop and he said I have a T56, there was nothing on the GM vis when I bought the car. No problems with the transmission though..shifts great.....just wondering...??
Old 03-26-2012, 03:39 PM
  #231
LFZ
LFZ's Avatar
If you have a 08..you have a TR6060 for sure.
Old 03-26-2012, 05:48 PM
  #232
Lethal427
Lethal427's Avatar
Default Built
Is there a 'built TR6060' version that is for over 600rwhp and will not carry over all the issues the stock one has? I have a 08 H&C, Stroker getting ordered mid April.
Old 03-26-2012, 06:06 PM
  #233
AzDave47
AzDave47's Avatar
Received 4,506 Likes on 2,597 Posts
Forum vendor RPM does extensive transmission enhancements and has a good forum reputation (I've not dealt with them-stock TR6060 with modest cold gear "nibble").
Old 03-27-2012, 09:00 PM
  #234
Rick@RKT Performance
Supporting Vendor
Rick@RKT Performance's Avatar
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
I have built many TR6060's for the 900 RWHP + crowd. The "built" unit consist of carbon blockers on the 1-4 gears/bronze fork pads/micro polishing gears. You can change out the gears for ZR1 ratios if you need more strength.
__________________
Quick Reply: [Z06] 2008 Z06 may be a flaw in some tranny's
