[Z06] Checkout our new Fan Control Switch....
#62
Jim, maybe I missed something, but my post asked whether you had a fan controller for my 2012 Z. Your post still indicates application is for Z through 2009. Do you have application for 2012Z? Thank you!
#64
Just launched....
Take complete control of your C6, Z06, or ZR1 coolant fan with our new Corvette C6 Fan Control Switch
This brand new Plug-And-Play control module installs under the hood, at the fan connector, and is designed to manually control the PWM coolant fan found on the 2005-2009 C6, Z06 and ZR1 Corvette. When the need arises to manually cool the radiator down, this module gives you complete control (high, low, and normal) of the fan with the simple flick of a switch. This kit can be installed in less then one hour, once you decide on where you want to place the control switch. This switch matches the style and look of cockpit switches used on all the C6 Corvettes.
Comes with easy to follow installation instructions.
Ordering info below.
Jim
Jim
#65
This looks like a very "cool" idea. With my ESC supercharger I may just have to look into this to help control my fans better!
#70
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
#71
C6 of Year Finalist (stock) 2019
#73
So please let me get this correct, your harness goes between the fan control module and the fan itself? I was hoping that this module replaced the fan control module, as I believe that is what is dead on my Vette. Can you please elaborate a bit on this please?
#78
You could try clipping those connectors off and re-wiring it with a connector rated for higher amperage.
#79
Supporting Vendor
David
David
