[Z06] alum. crush washer on oil drain plug?????
I haven't taken the drain plug off my car yet for an oil change. but I've seen pictures of the drain plugs and it has the little o-ring on it.
Those of you that have done an oil change do you change that o-ring out when you change the oil???
I was wondering if instead of using that o-ring an alum. crush washer will do the job of sealing the plug to the pan. Most import vehicles use the crush washer instead of a rubber or plastic seal to prevent drips. The washers are replaced everytime you do an oil change.
I had a milodon oil pan on an engine project done a while back (Ford 408W), that drain plug on the pan had a plastic washer on it. After a couple of oil changes the washer got all distorted and was causing a leak. I replaced it with an alum. crush washer and it sealed the drain plug perfectly.
Finding an alum. crush washer for the LS7 drain plug shouldn't be a problem and would be a better solution to the rubber o-ring setup.
Tony
Tony
If you want to extend the life of the seal. From my experience, the O-ring can age and turn brittle. In some BMW applications, the two O-rings for the oil filter canister are supposed to be replaced every filter change.
I can see that aluminum crush washer will last longer. I would try copper crush washer too. Personally, I don't replace a drain crush washer every oil change. However, if you are going to replace a crush washer every oil change, there is not really a need to change to crush washer; might as well get a bunch of O-rings and replace it every time.
Keep the rubber one. It will last a long time. Do not overtighten the plug. I do many, many oil changes and seldom replace the seal. They are only damaged when overtightened.
I will still look for a crush washer for this application. The one time the rubber o-ring will degrade and leak will be the one time you reinstall the drain plug then notice after a period of time a drip on the floor of your garage.
The crush washer will leak before the rubber one will. The drain plug has a recess place for the rubber, Therefore you should not have any problems.
Honda Accord engines use an aluminum crush washer and I have owned Hondas for over 30 years changing the oil myself. I find that the washer has to be reversed on the next oil change and then pitched for a new one after that. The aluminum takes a set that might not seal good the next time you install it has been my long term experience.
