Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- How to Take Care of Your Hydraulic Clutch
Step by step instructions for do-it-yourselfers.
[Z06] Clutch Pedal Issues—How-To Prevent and Cure
#361
I have owned several Z06 vettes and have had trouble with the clutch in every one. I have tried this fix of cleaning and changing the clutch fluid and every time it did nothing to fix my clutch pedal issue. (sticking to the floor) The only thing that fixed it was a new clutch and pressure plate. The clutch pressure plate fingers are the problem, they are weak and tend to not release under hard acceleration.
#362
1st Gear
I am a new Z06 owner. 2006 with 34K miles on it. Shifting /starting into first seemed sticky so I switched out the clutch fluid today. It is so much better now, shifts smoother and is really tight. Thanks for the info Sarge!!!!
#363
Thanks for you insight into this matter. I had problems with my clutch peddle as well. I used this info at the dealership & ask for assistance with my problem. Dealership had to replace the slave & master cylinder in mine car
$2400 bucks. I fought with them & GM to help me with this issue. My 06 Z06 only has 15k soft miles on it although it is 9 yrs old. I was told that they couldn't help because it was out of warranty. This was in August 2015 then in September I received a letter from GM that they were going to provide additional protection for 10yrs from first service or 120k miles. I'm still trying to get my money back but looks like they will take care of it. If not i'm sure the letter will stand up in court.
#364
How come They are giving u 10 year 120k??
#365
There have been messages to dealerships to tell owners of the problems with the clutch hydraulic system. I've always had my car serviced a the dealership so I would have expected them to tell me that fluid needed to be changed which was never done. I first learned of the problem after the clutch stuck to the floor while at the dealership. That when i started checking the forum only to find out others have had the same problem. I contacted GM after i couldn't get anything done with the dealership. GM told me that they wouldn't be able to do anything either in late August. Then in September got a letter came from GM in September 2015 a month after the work was done on the car. Telling me that they would pay for the repair. To date i haven't got money yet however, the letter they sent me is pretty damning.
#366
