Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- How to Take Care of Your Hydraulic Clutch
Step by step instructions for do-it-yourselfers.
[Z06] Clutch Pedal Issues—How-To Prevent and Cure
The Thing I dont get Ranger is. After looking through all the fluid ratings on the link you attached. It seems the Valvoline Pro 3/4 has some of best ratings and bang for buck compared to all on the list. So how could it be performing so poorly in my Z? I dont even see Prestone on the list do you know what the Boiling points are for that one? Thanks
The main symptom that sweeps across Corvettes of 1997-2009 and many other brands is pedal issues at high-rpm. I am assuming that's what you are experiencing sometimes.
Given that, If your clutch fluid is very fresh and clean and you are still having pedal issues, then you may have a damaged seal in the hydraulics. The cheapest and most accessible part to change is the master cylinder.
But before taking that path, I'd swap to a different fluid that is proven to work well in the C6Z. That would be the two fluids in the video. BTW, regarding the Prestone DOT4 specs, 500 dry boiling and 311 wet boiling. If the fluid is kept fresh, then the wet boiling point (defined as 3% water content) never comes into play.
Ranger
Thanks so much Ranger! I had been meaning to take a look at my fluid for longer than I would like to admit :o but finally did it a couple of days ago (using instructions from your website). I'm actually going to participate in my first drag session tonight (1/8 mile track) so I wanted to be sure it was clean before I went... it needed changed badly.
This video explains the process very clearly. Thanks again.
Hey Ranger welcome back......Guys when doing this fluid change remember as stated in the video cover your fender with a towel.If the fluid gets on your fender you are in trouble.
The framework for defining pedal issues is setting aside pedal hangs on the launch, which are characteristic of the LS7 clutch if the release is not fast and below 3600-3800.
Ranger
Ranger
Ok ill try that out and try to find the Prestone 4 thankyou what are your views on dumping the clutch? everyone seems to tell me im doing more damage and wear by easing the clutch out quickly and launching. Rather than just getting it up to 4000 or so and dumping it.
Very well done video.
I have been following your advise changing the fluid frequently and using the GM Super Dot 4. I have ATE Super Blue (amber) that I use for brake fluid but am reluctant to switch as I have had NO CLUTCH PROBLEMS
I WOULD RECOMMEND THAT YOU USE RUBBER GLOVES WHEN SERVICING !!!!!!!!!!!
DH
DH
WELCOME BACK RANGER.....THANKS FOR ALL YOU DO FOR US
I use Motul 600, works great,never had a problem, have OEM GM as well. Great job on the video...................
Best Regards,
Tommy
Best Regards,
Tommy
Hi Yaroslav.
You can compare the specifications of good fluids in this chart
The Motul 5.1 looks fine if it's available where you are.
Ranger
Ranger
#35
Great post, John. Are you going to Track Attack 200(? I hope so.
Jim
Jim
#37
Where can you find that syringe. I have one that I use but its half the size of the one you have. HAd a tough time just finding the one I have. How many times do you think it would take to flush through the valvoline with the new prestone to get through the whole system? Thanks
#38
I also use Motol 600 on my 2008 Z06. I had to Mail order it because I could'nt find it in the local stores. I "Turkey Baster" it out about every 2 weeks and I drive it about 2-3 days a week. So far my clutch is holding up great.
Ranger is the Man !
Ranger is the Man !
#39
So another words you still would recommend a quick release rather than a "dump".
Go to a local medical supply store and get their largest syringe. It should cost about $2.00. I use one of these and can empty the clutch master cylinder in one pass. And thanks to Ranger, I've had no clutch troubles.
