C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] OEM C6 Z06 Wheels - Can a 345 fit on the rear
Old 02-16-2009, 10:58 AM
JG853
JG853's Avatar
Default OEM C6 Z06 Wheels - Can a 345 fit on the rear
Just wondering - Can a 345 fit on the OEM C6 Z06 rear wheels? If so, would the tire size be a 345/35/19?
Have people done this or is it a bad idea?
As always, thanks for the help.
JG853
Old 02-16-2009, 10:59 AM
jerseydrew
jerseydrew's Avatar
yes they will fit but the size would be a 345/30r19. many people are running on 345's
Old 02-16-2009, 11:14 AM
Zoxxo
Zoxxo's Avatar
Got 'em on my Z and they are just fine
(to be correct, mine aren't stock rims but the size of the rims is stock.)
Z//
Old 02-16-2009, 11:46 AM
JG853
JG853's Avatar
Thanks for all of the help.
Best Regards,
JG853
Old 02-16-2009, 02:29 PM
Flareside
Flareside's Avatar
IMO it depends on the tires. Some brands look just like stock at 345, other brands look kinda funny at the sidewall on the stock wheel. I would look for pictures of the exact tire mounted (if you care about such things).
Old 02-16-2009, 02:43 PM
ptaylor_9849
ptaylor_9849's Avatar
I just bought Nitto Invo 345's. They will be here tomorrow.
Old 02-16-2009, 03:07 PM
Nate@CorvetteGarage
Supporting Vendor
Nate@CorvetteGarage's Avatar
Cruise-In I Veteran
St. Jude Contributor '04
The Nittos and Michelin PS2's run fine on the stock 19x12 wheel.
Nate
__________________
Corvette Garage Inc
Xtreme Motorsports
1.806.771.0205
Website: Click here for Corvette Parts and Accessories!
Email: sales@corvettegarage.com
Old 02-16-2009, 03:24 PM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,090 Likes on 574 Posts
Nate
On Michelin's web site it lists the 12" wide wheel being the optimum width wheel for their 345/30/19 PS2s.
Dave
Old 02-16-2009, 03:41 PM
AtlBlkZ06
AtlBlkZ06's Avatar
I don't have first hand experience with this, but don't you have to run 295s up front to avoid the engine drag control message at high speeds?
Old 02-16-2009, 06:13 PM
Zoxxo
Zoxxo's Avatar
Why do you care about the message? It's not a "warning" at all. It's just a driver notification that's saying "what you're feeling right now is me and not something wrong.". As long as you know what it is, you can safely ignore it. I have 345's on mine (with stock size fronts) and the only time I get the message is when decelerating from high rpm in lower gears. It's not an issue. Really.
Z//
Old 02-16-2009, 10:43 PM
seamus2154
seamus2154's Avatar
You do want to keep close to the stock ratio front to rear. 1/2 inch or 1 inch I can't remember right now. But I have 345/30 mich ps2's rear and 285/35 mich ps2's front which keep it almost exactly as the stock ratio. No lights or abs,t/c, or a/h problems for 3000 mls now.
Old 02-17-2009, 12:21 AM
ranger1
ranger1's Avatar
I have 345 MPS P2, on the rear. No issues, just better grip...
Garry
Old 02-17-2009, 01:24 AM
edensknight
edensknight's Avatar
Yes, indeed, you have the right idea! Moreover, a 345mm tire size is an ideal tire width size for a 12 inch wide wheel width. And, within the high performance tire industry, we are all grateful to finally see a "30 Series" (i.e., 345/30-19) tire released in the Michelin PS2 lineup. This taller sidewall aspect ("30 Series") allows for better grip (i.e., less loss of traction at linear launch) over the much shallower "25 Series" tire sizes. Please feel free to PM me for further insight. Lastly, you may also perform an advanced search under my avatar name to research more information regarding proper tire and wheel fitment parameters. Best of Luck to You!
Old 02-17-2009, 02:46 AM
C5_PIG
C5_PIG's Avatar
Any issues with a car that is lowered on stock bolts?
Old 02-17-2009, 05:45 AM
siggi-annette
siggi-annette's Avatar
PS2
Old 02-17-2009, 09:44 AM
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
Im running 275-35-18 and 345-30-19 PS2s on stock size wheels. No issues and no warnings.
My car is lowered, no issues.
Nate
Old 02-17-2009, 04:38 PM
Dreamin
Dreamin's Avatar
Mich no longer makes a 285/35/18 PS2
To OEM C6 Z06 Wheels - Can a 345 fit on the rear
Old 02-17-2009, 09:45 PM
TWPVETT
TWPVETT's Avatar
Default PS-2's
Same as Nates; PS-2's 275/35/18 345/30/19 Perfect.
Old 04-08-2009, 03:32 PM
JakeFusion
JakeFusion's Avatar
The Nitto NT05 in 275/35-18 and 335/30-19 are also perfect.
Old 04-08-2009, 05:32 PM
RichieRichZ06
Supporting Vendor
Support Corvetteforum!
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
295's in front and 345's in back is the only way to go.
Quick Reply: [Z06] OEM C6 Z06 Wheels - Can a 345 fit on the rear
