[Z06] Milled heads how much
Unless you have a non stock cam with more overlap you really can't raise the LS7s compression ratio very much with out pump gas problems. Stock it is running somewhere around 8.7 to 8.9 dynamic. If you have an aftermarket cam search for a dynamic compression ratio chart with the cam timing event specs vs static compression ratio.
Tomorrow Wed 3/18..getting my 08 Z LS7 heads milled .40". Bringing the compression to 11.6:1. on pump gas. Going with the QM550 cam. Quality Motosports doing their magic once again.
972/754-3387 Call Q.M. and ask Patrick for details.
It varies depending on your valve clearance, which is different depending on your cam specs and rocker ratios. I have somewhat of a high lift cam so I only went .020". With stock gaskets, that left me with .072" clearance on the intake valves. The general rule is not to go below .080", some say .050" is really pushing it but I feel safe where I'm at, I'll just set my rev limiter to 7200 instead of 8000 rpm.
Here is a cool CR calculator:
http://www.rbracing-rsr.com/compstaticcalc.html
http://www.wallaceracing.com/millcalc.php
Former Vendor
I find it best that milling the heads .40 and then running .40 thousandth thick gaskets performs better and more consistent especially with a cam.
We are currently running a milled heads/cam kit special for $3,000 tuned and installed!!!
Thanks,
Carlos
I all depends on the car, the cam and the tune. Many people like to mill the heads and then put stock size gaskets back on and thus negating the mill job and then expect to see a big jump in power.
Thanks,
Carlos
Thanks,
Carlos
I only went .020 due to 92 octane and DCR concerns with the cam I'm running. Safe > sorry and you can never put material back on that you mill off.
Thanks,
Carlos
Thanks,
Carlos
