[Z06] Muffler Mod v.s No Mufflers
Hey guys well I just did the muffler mod and love it, but I think its still a bit to quiet. I am looking to increase volume by about 30%. Does anyone have any experience with the muffler mod v.s removing the muffler and running straight pipes from the H pipe back. Would this be louder than the muffler mod, because isn't the muffler mod essentially a straight pipe when the valves are open. Also, I don't want to do headers for warranty issues, and no x-pipe because I love the crackling and popping the H pipe produces. Thanks.
With out mufflers of any kind, the car is going to drone, and be very loud, we have done this in house, and personally I hated it.
If you want a louder exhaust get some long tubes, and and x pipe and then run the B&B bullets! That is generally a loud set up!
Maybe the OP is trying to get a good sound without spending around $1200? The muffler mod is like $200 usually and straight pipes would prolly cost that much right? I'm looking into the straight pipes also but fear it may be too loud? On my base C6 I have Borla Stingers, would the straight pipe be louder than that on a Z06? I just really want to cut the mufflers off and run two pipes all the way to the back.....
Dont get me wrong, I am not about the most expensive route, but you want to keep some of the quality to the car.
Straight pipes custom made with nice tips will run over 500, plus they really are very loud. Atomicfusion has strait pipes on his car currently we did for him, and I believe he is over it.
The best way would be long tubes, x pipe , muffler mod for a minimal cost, and you will gain performance at the same time.
Going in for the muffler mod tomorrow. Have AR headers and X-pipe with LG Man **** (always have trouble typing that ). I'll do a pre-mod sound clip and post mod sound clip to give a comparo.
John
John
When I 1st got my Z the original owner took the muffs off and ran straight 3" pipe out the back...it was insanely loud and it really droned badly. I actually wore earplugs until I got a proper exhaust put back on it.
You can hear an idle clip of mine on the cam/exhaust sound thread with the straight pipes.
The muffler mod is great, but I would like it to be a tad bit louder. Changing the H pipe to an x pipe won't really increase sound, and the car won't pop and gurgle as much on deceleration. I don't want to remove my cats, so the only other option is straight pipes. Are straight pipes that much louder than a stock with muffler mod? I thought that when the valves are open it is essentially a straight pipe?
I just don't want to waste resources by getting straight pipes only to realize it's the same in terms of noise level as the muffler mod.
My buddy has a c5 Z06, and he has headers going into the stock cats and x-pipe. The car sounds bad a$$. It is also surprising quite when your not getting on it. Its got me thinking about a strait pipe out the back first with stock manifolds, then maybe trying headers. just a thought.
The best thing for you would be to try it, and if you get tired of it, put the mufflers back on!
-Brandon
Really, even with "the muffler mod" where the perforated opening are blocked? I know the 2 inner valved pipes are completely straight piped when open. The only thing that might not make it a true straight pipe is the outer tips don't get blocked off so even with the valve open some of the flow might be going to the outer tips reducing noise. Doe anyone know how the outer tips muffle? It seems like most of the flow goes to the inner tips because their is a lot more carbon buildup on those tips when they are open.
There is a diagram in the PDF file that shows how the muffler works.
Muffler Mod Instructions (PDF File)
Alright guys I have decided to go the straight pipes route, does any vendor sell straight pipes with quad stock like tips? How much would I look to pay for an exhaust shop to custom make these. It si my understanding that when the over axle pipes connect to the muffler it goes from a 3 inch pipe to a 2.5 inch pipe. I want to basically keep it 3 inches all the way back to the quad tips. I would think it shouldn't cost more than a couple hundred bucks for a quality made item?
Thanks for the help.
