[Z06] Control your 2006-2013 Z06 Bi-mode exhaust from your Car2U visor! No Fobs needed!
#81
I currently have a variant of the LG Man Switch. I still will want to use this switch to control the exhaust as I prefer the dedicated physical button over a wireless option. It has a 'Open' and 'Closed' mode.
I think I'd want 'Open' to be 'Open' all the time, like it is today. But then with 'Closed' I'd like to be able to configure the RPM to a User Setting as well as change it to be Completely Closed when I need it to be.
What options do I have?
#82
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
It allows you to have 3 modes, full open, full closed, and user selectable rpm opening.
It uses the door panel lock button to control the exhaust. See the video below.
Here is the Exhaust Commander Elite Thread:
Here is the vacuum solenoid harness link.
http://shop.sunsetorangecreations.co...7&categoryId=5
If you use these two products together you would achieve what you are looking for.
If you need additional info, give us a call or send us a message.
Ben
#87
#88
St. Jude Donor '13
In order to keep the butterflies closed after 3500 rpm you need to bypass the factory bi-mode computer. That is what the vacuum solenoid harness is. It wires around the GM computer and then allows you to modulate the signal to the solenoid directly.
#89
St. Jude Donor '13
Place your order now and take full command of your bi-mode exhaust using your universal visor remote!
No Fobs needed! Lifetime warranty! Simple 5 minute install!
#94
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
We just installed another one this morning for a customer. I have yet to find a product that works so well and installs so easily.
Thanks Ben!
Thanks Ben!
#97
St. Jude Donor '13
On Sale now! Lifetime warranty!
No keyfob remotes needed, use your built in visor remote!
100% ZERO BATTERY DRAIN in every configuration!
Get yours now!
Get yours now!
