[Z06] Omega 29023 Jack
Omega 29023 Jack
Received new jack today. The handle does not store upright,it comes down to a 45 deg angle. Is this normal for all of them? It does not seem right to me. Also I had bought the adaptor for the hole in the frame at Mid America Motorworks pART #100-004 and it does not fit into jack. I will have to bring it to a machine shop to shave it down. Is this my best approach?Thanks guys!!
The Omega 29023 has a 1" pin hole. Many other jacks use a larger pin. The "other" dimension escapes me at the moment. I have this jack. The handle on mine does not store vertically either. My fix was to drill either side of the frame and put a couple of quick release pins thru the frame which hold the handle upright when not in use.
It's only advantage is the long reach. It's one heavy sumbitch (125lbs)and I think it takes way too much effort on the handle to lift the car. A buddy has the same jack and his is already showing signs of failing (leaks) at less than 1 year old. Having had it for about a year now I don't think I'd recommend it. It's "OK" but I'm sure there are better choices out there albeit at greater expense.
