C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Going crazy!!! Need a BIG driveway ramp
Old 11-15-2009, 11:42 AM
BrnEyzR1
BrnEyzR1's Avatar
Default Going crazy!!! Need a BIG driveway ramp
I know there are other posts about driveway ramps, but I need a ramp that is about as big as a sheet of plywood and 1" to 4" taper.....the city won't let us pour more concrete. I'm just going crazy pulling out all the wood it takes to get my car out and putting it back when I don't drive it or its street sweeping day plus it looks like crap... any ideas?
Old 11-15-2009, 11:56 AM
arkus
arkus's Avatar
Check out Griots . They make something like that .
Old 11-15-2009, 12:18 PM
phantom427
phantom427's Avatar
i use the ramp from griots, works good but i still need to pull out at an angle to prevent scraping. Driveway entrances where i am suck total *** for any vehicle that does not have the ground clearance of a 4x4.
Old 11-15-2009, 12:20 PM
BrnEyzR1
BrnEyzR1's Avatar
thank you!!
Old 11-15-2009, 12:25 PM
viperZ06
Support Corvetteforum!
viperZ06's Avatar
I scrap backing out. For some reason I don't when I go out front ways.
Old 11-15-2009, 12:46 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Try popping a wheelie just before the bump! Good luck
Old 11-15-2009, 04:14 PM
Nick 02 Z06
Nick 02 Z06's Avatar
I had this same problem. I moved and couldn't get my car up the driveway.
Here are pics of what I made:
It isn't pretty but it works....
I got these pieces of plywood precut from Lowes and they were almost exactly the length I needed to make the transition with out scraping. Good luck!
Old 11-15-2009, 04:22 PM
arkus
arkus's Avatar
I like that . Looks like it works well . I would make something like that except if some pedestrian trips over it they might want to file a claim . That's my only concern with that .
Old 11-15-2009, 04:23 PM
jerseydrew
jerseydrew's Avatar
man tat sucks! you gotta set these up EVERY time you wanna take the car out? and then stop in the street and put them away. damn
i'd hate to get caught in the rain on the way home and have to run in and set this crap up.
Old 11-15-2009, 04:26 PM
Nick 02 Z06
I don't leave them out. It put them out when I pull the car out. Then put them back in the garage. They are very light weight. If I go for a short ride I'll leave them out though. I complained to our home owners association and was going to put a couple thick pieces of sheet metal out but they wouldn't let if fly.
Old 11-15-2009, 04:27 PM
Nick 02 Z06
It does suck but it's worth it.. It rarely rains in So Cal!!!
Old 11-15-2009, 05:30 PM
z06clif
z06clif's Avatar
Have the same problem. I solved it by backing into the driveway and pulling out frontways. The size of the rears keep the car higher giving it the right clearance.
Clif
Old 11-15-2009, 05:31 PM
LT5 John
LT5 John's Avatar
I have the same situation, the way the driveway apron is sloped for water drainage. What I do is, when pulling out of my driveway, I back out onto the street at a 45 Deg angle, an pull in at a 45 deg angle...it scrapes very very litle almost not at all...
Old 11-15-2009, 05:32 PM
andy82
andy82's Avatar
2017 C7 of Year Finalist
Same here, not sure why But I still need a pice of wood to get in or out...
Old 11-15-2009, 05:34 PM
andy82
andy82's Avatar
Compared to my piece of wood this is REALLY pretty
Old 11-15-2009, 06:29 PM
Luweegy
Luweegy's Avatar
I would just stradle that to get in.I've got a friends driveway like that and have no problem.My car is slammed on coilovers.
Old 11-15-2009, 07:03 PM
Nick 02 Z06
My 02 Z06 sits higher than my 07 and it scrapped when stradling this driveway. The pictures don't do a good job of showing how steep it really is. My wifes Envoy scrapes sometimes coming out of this driveway. Alot of the time there are other cars parked on either side of the driveway so there is no way I coud stradle it anyway. My car and I'd rather not scrape. Your car go ahead and scrape. Enjoy.
To Going crazy!!! Need a BIG driveway ramp
Old 11-15-2009, 09:34 PM
BrnEyzR1
BrnEyzR1's Avatar
Thank you!! That looks great!! my driveway is alot 'steeper' but yours is closer to what I need to do.... thank you so much!!!
Old 11-16-2009, 02:09 PM
Allzwell
Allzwell's Avatar
Cruise-In VIII Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Race ramps will custom make you any configuration that you need. I am going to have them make one for me so I can quite dragging plywood around.
Old 11-16-2009, 02:14 PM
dfinke23
dfinke23's Avatar
Race ramps are the way to go.
Quick Reply: [Z06] Going crazy!!! Need a BIG driveway ramp
