C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
The actuators are on the exhaust tips.. you will/should see the vac lines going to them if you look up from the rear of the car. That's all I'm familiar with so far, except the fuse.. I've only had my car a couple of weeks.
Remove both passanger rear tail light assemblies. This is easy, three torx screws per light, removal of both will give you ample work space for both hands. The solenoid is located behind the inner passanger tail light, it has two vaccuum lines and one electrical pin plug. The dealer diagnosed, changed part and no problem since.
what would cause the valves to stick open on the exhaust?
There're a few things as others have noted; however, assuming you've a valid warranty just have your dealer find & fix it.
Save yourself the aggravation.
