[Z06] LOUDER/MEANER ??: muffler mod VS B&B fusions ?
....BOTH WHEN OPEN.
I keep going back and forth between the two. I read great reviews/posts on both. I'm just looking for an improved/louder/meaner sound with the ability to tune in down on the highway. I'm just having a hard time thinking $2k is worth a SOUND. IF I was to get increased performance (that is noticable) maybe it would be easier. Need some advice. Getting antsy to do something within the next week.
Thanks!
Thanks!
Unfortunately, I don't know anyone in my area (ATL) who has the two exhausts.
Which drones worse? I've been reading the modded muffler doesn't drone when closed while the B&B does some when closed.
I was absolutely blown away by the sound of the modded mufflers. Cost a total of $80 and rivals any cat-back system. When closed, completely silent, just like stock. Open them up, and it absolutely roars! Its not a cheap alternative, its exactly the way the car should've sounded and been setup from the factory. There is minimal drone when open at cruising speeds, so little that I rarely, if ever, close it. It sounds amazing and is also still completely reversible. Really the best of both worlds.
guys im in the market for an exhaust system and im so lost between Corsa and the B&B
reason why i love B&B is sound but hate the drone everyone is talkin about
reason why i love the corsa is no drone but doesnt sound as good as the Corsa
i'll be installing a AR headers too so help guys ppl with those 2 exhausts some feedback plz
Z0sic,
without headers, I love the corsa. With headers, I like my exhaust to have the option (butterfly valve). Weather it be the stock exhaust or B&B. I had the corsal before installed headers & love it. But once the header was installed, the corsa had to go so I went back to stock.
The B & B fusion is one of the highest quality exhaust systems I have ever seen or put on a car. The sound is every bit as good as the looks, but it will drone at a steady 2000 to 2500 rpm. They all do to some extent. If I want a nice quiet ride, I jump in my wife's 07 vert. However, every once in a while...........OK, maybe a lot more often, you really want to hear those ponies scream.
By the way, my buddy also did the B & B, then went ahead with Kooks headers, Katech cam kit, tune, etc, and the dyno showed 2 more HP with the mufflers closed vs. open. Now you ought to hear his exhaust with the mods......sounds like the proverbial 800 lb gorilla. You can actually feel the pounding in your chest.
I've done both also. Liked the mod sound, but like the looks and sound even more with the Fusions.
I have modified Z06 mufflers on my (with a big *** cam in the car and catless headers), and the guy who did mine said the Z06 mufflers are quieter when closed and louder when open than Fusions. There's a local guy with an extremely similar setup to me, except he has Fusions, and his car was the comparison. Personally I love how mine sounds with the modded mufflers... but if you have a stock cam, it's going to sound like a bass boat.
If you want loud/mean check out the LG GT4 cat-back. I also have the LG Pro long tubes, HF cats and X Pipe and it is LOUD!!!! The drone is pretty bad at low speeds and cruising at at 2,000 - 2,300 rpm's.
Personally, I think the Fusion sounds way better than the mod when open, but it also drones when closed. To me, the muffler mod sounds like what it cost, cheap. In fact, the sound is so hollow when transitioning from closed to open (when driving in the 2500-3500 rpm region) that I can't wait to remove it. Just not sure where to go next. The mod does sound good once open, but not as good as the Fusion. And it doesn't drone closed.
Anybody know of a way to disable the RPM based opening and closing so that it stays closed unless you hit the button? If I could do that, I might like it better.
Bob
33036 / Katech # 29
If you decide to go with the mod, then post up where you had it done. I am thinking about doing the same, but I don't know where to have it done, or if I would just go with a different setup.
Please explain what the modded muffler consists of for a total cost of $80? 2 benefits i see - low cost and easily reversible
thanks
http://forums.corvetteforum.com/c6-z...iy-thread.html
....BOTH WHEN OPEN.
Thanks!
Thanks!
I got quoted 200 to get the job done. I don't have a lift so has anyone done this mod with jack stands, or should I stop being cheap and pay the 2 hundred. I don't weld but can have a friend weld.
PS, the fusion definitely wins in the "looks" category....nice looking set of pipes
If you're in St. Louis, I know somebody who will do it. They did it to mine during a clutch swap. It's not really reversible, though, depending on how you do it. There's the option of adding a switch to open the mufflers any time you want, but everybody here is talking about cutting them open to do some internal changes.
